Lower your Voice Alert
Emily Sharrard
I've never noticed the "Lower your voice Alert".  A user happened to find it.  You can turn it off via the phone settings.  I am trying to find out if it can be globally turned off.  Also, when was this feature implemented.   Not finding anything in Administration/Maintain & Operate.  Also poked around phone configuration, common phone profiles, enterprise settings.
Jaime Valencia
It was introduced on FW 12.7(1), the RN cover it.
java
if this helps, please rate
9 Replies 9
Leo Laohoo
It is called "sidetone". It help the talker lower his voice by piping his voice back to the headset.
Jaime Valencia
java
Ah yes, release notes.  Did not look there.  Thank you.
dp215
Check out the new 12.7 features in the ciscolive doc or release notes. The feature can be disabled.
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKUCC-2050.pdf
Thank you for sharing this.
Jaime Valencia
FYI, I just saw confirmation this is not centrally managed, this is a PER device setting with no control from CUCM.
If you wish to see this to be centrally managed, reach out to your SE/AM to submit a PER
java
There's an enhancement request to disable it by default, that will probably be the fix that comes first
CP-88xx - Make 'Lower Your Voice Alert' Disabled By Default
CSCvt04894
java
Good to know, Jaime.  We never know for sure how Cisco prioritizes things.  Thanks!
Response Signature
