10-29-2012 07:56 AM - edited 03-16-2019 01:55 PM
This is a new installation and I have a network connectivity issue, in my CUCM 8.6 over VMware VSphere 5 UC210. In the vSphere client I have connectivity to default gateway and to all networks. But, in my CUCM , using the CLI, I can't ping to or from the CUCM.
The eth0 have the link detected yes and the status is up.
Any idea?
TIA
Cristian.
10-29-2012 08:23 AM
Is the proper vSwitch assigned to the virtual machine? Does that vSwitch include the proper NICs?
Chris
10-29-2012 10:46 AM
Dear Chris
The conectivity is by a switch with cannel port configuration.
For the vSphere conectivity, please see below:
TIA
Cristian
10-30-2012 07:42 AM
Hi Guys
Any idea?
Anyone has this happened?
TIA
Cristian
10-30-2012 07:47 AM
So, you can get to ESXi, but not the CUCM?
What if you remove the VLAN from the vSwitch?
Can you post "show network eth0" from CUCM CLI?
Chris
10-30-2012 08:08 AM
Dear Chris
1.- you can get to ESXi, but not the CUCM?
Yes, right.
2.- What if you remove the VLAN from the vSwitch?
Set Vlan ID none, I loss the conection to IP 10.199.0.6 . Set Vlan ID 1, I loss the conection to IP 10.199.0.6. Set Vlan ID 4095, I have connection.
This is the config in the switch.
Port Channel
interface Port-channel3
description Port-Channel UCS
switchport trunk allowed vlan 1
switchport mode trunk
interface GigabitEthernet2/0/1
description Conexion UCS 1
channel-group 3 mode on
spanning-tree portfast trunk
interface GigabitEthernet2/0/2
spanning-tree portfast trunk Port Channel
3.- Can you post "show network eth0" from CUCM CLI?
TIA
Cristian.
10-30-2012 02:21 PM
Could you share this outputs from the switch?
show etherchannel summary
show etherchannel detail
show interface trunk
best regards
10-31-2012 12:41 PM
Dear Arturo
Datacenter#show etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
3 Po3(SU) - Gi2/0/1(s) Gi2/0/2(P)
Datacenter#show etherchannel detail
Channel-group listing:
Group: 3
Group state = L2
Ports: 2 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: -
Ports in the group:
Port: Gi2/0/1
Port state = Up Cnt-bndl Suspend Not-in-Bndl
Channel group = 3 Mode = On/FEC Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po3
Port index = 0 Load = 0x00 Protocol = -
Age of the port in the current state: 08d:01h:56m:20s
Probable reason: trunk mode of Gi2/0/1 is dynamic, Gi2/0/2 is trunk
Port: Gi2/0/2
Port state = Up Mstr In-Bndl
Port-channel = Po3 GC = - Pseudo port-channel = Po3
Age of the port in the current state: 06d:21h:36m:37s
Port-channels in the group:
Port-channel: Po3
Age of the Port-channel = 49d:17h:02m:47s
Logical slot/port = 10/3 Number of ports = 1
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = -
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi2/0/2 On/FEC 0
Time since last port bundled: 06d:21h:36m:47s Gi2/0/2
Time since last port Un-bundled: 06d:21h:54m:42s Gi2/0/2
Datacenter#
Datacenter#show interface trunk
Port Mode Encapsulation Status Native vlan
Po3 on 802.1q trunking 1
Port Vlans allowed on trunk
Po3 1
Port Vlans allowed and active in management domain
Po3 1
Port Vlans in spanning tree forwarding state and not pruned
Po3 1
Datacenter#
TIA
Cristian
10-31-2012 12:47 PM
and in the CUCM , but I can´t to reach the default gateway.
TIA
Cristian
11-03-2012 08:06 PM
Wild guess, but have you tried updating VMWare Tools? There might be something funky with the virtual network interface.
11-05-2012 11:12 AM
Dear All
I solved the problem. No vlan in the switch and in the VMWare.
Cristian.
11-05-2012 11:16 AM
Right, I never use any VLANs in ESXi as per my inital post and it has always worked well.
Chris
11-05-2012 01:08 PM
But the documentation say to use VLAN.
Thanks for you support.
Cristian
11-05-2012 01:25 PM
Have you looked at the switch logs for any errors? I had a customer deployment using C210s and found that one of the port-channel ports was in the (s) suspend state, this was due to flow-control enabled on the interface, this was evident from the logs.
Allan.
