Number of translation rules in a voice gateway
Jeff Bankston
I am an old dog in the UC world, and past versions of IOS had a limitation as to the number of voice translation rules you could have in a translation profile.
Does anyone know what the limit is for a 3925 running 15.1 series code? I have a client with a special condition where I might need upwards of a hundred rules in one profile, and don't want to crash the gateway with a test if I can already know what the limit is.
Thanks, Jeff
Nadeem Ahmed
Hello Jeff
15.1(4)M which has 100 rules
Router(config)#voice translation-rule 1
Router(cfg-translation-rule)#rule ?
<1-100> Translation rule tag
Br, Nadeem Please rate all useful post.
9 Replies 9
Nadeem Ahmed
Hello Jeff
thanks folks, most appreciated.
-Jeff
Just remember u can have only 15 rules per translation rule. Rule 16 will not be accepted
Best Regards
I have a 2960 voice gateway running 15.0(2)EX5
I cannot find the number of rules limit.
Can someone help me ??
Hi alainauer
Cisco 2960 is a Switch not voice gateway.
http://www.cisco.com/c/en/us/products/switches/catalyst-2960-series-switches/index.html
Grab below outpout
show tech
show tech voice
Please rate if you this post helpful.
Mohammed Noor
Sorry!!!!!
I have a 2921 voice gateway with version 15.3(3)M2
William Bell
See:
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/vcr3/vcr-r1.html#wp8518966320
Scroll down to the command history table. With 15.1(4)M, the number of rules was increased from 15 to 100.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
thanks for the link!!!!
Best Regards
Rajeev Samantha
Thanks, I have had the same issue and solved now.
Rajeev
