10-12-2012 07:38 AM - edited 03-16-2019 01:39 PM
I don't have any more hair to pull out! I've been stuck trying to register these phones for the last month or so. I know I'm missing a small detail, it's always something small that's missed. Can someone please look over my configures and point me in the right direction. It will be well appreciated, thanks.
Solved! Go to Solution.
10-12-2012 10:56 AM
What the TFTP server on the Phone config?
Please rate this post.
10-12-2012 01:33 PM
Sorry for the over flow. This should be everything.
Router#sh ip int bri Interface IP-Address OK? Method Status Protocol FastEthernet0/0 unassigned YES NVRAM up up FastEthernet0/0.1 192.168.3.24 YES DHCP up up FastEthernet0/0.2 192.168.4.1 YES NVRAM up up FastEthernet0/0.3 192.168.5.1 YES NVRAM up up Router# Router# Router#sh run Building configuration... Current configuration : 4540 bytes ! version 12.4 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! ! no aaa new-model clock timezone florida -5 no network-clock-participate slot 1 no network-clock-participate wic 0 ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 192.168.3.10 192.168.3.117 ip dhcp excluded-address 192.168.4.1 192.168.4.10 ! ip dhcp pool ITS network 192.168.4.0 255.255.255.0 dns-server 65.32.5.74 default-router 192.168.4.1 option 150 ip 192.168.3.22 ! ip dhcp pool data import all network 192.168.5.0 255.255.255.0 dns-server 65.32.5.74 default-router 192.168.5.1 lease infinite ! ! no ip domain lookup multilink bundle-name authenticated ! ! ! voice service voip allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip redirect ip2ip h323 sip registrar server ! ! voice class codec 1 codec preference 1 g711ulaw ! ! ! ! ! ! ! ! ! ! voice register global mode cme source-address 192.168.4.1 port 5060 max-dn 72 max-pool 24 authenticate register create profile sync 0390373217450378 ! voice register dn 1 number 1000 name SIP1 label Test Phone ! voice register pool 1 id mac 000D.BDC0.265B type 7940 number 1 dn 1 dtmf-relay rtp-nte voice-class codec 1 username 3001 password 3001 ! ! voice translation-rule 1 rule 1 /9193555570/ /1000/ ! ! voice translation-profile Incoming_Called_Numbers translate called 1 ! ! ! ! ! ! archive log config hidekeys ! ! ! ! ! ! interface FastEthernet0/0 no ip address duplex auto speed auto ! interface FastEthernet0/0.1 description OUTSIDE INTERFACE encapsulation dot1Q 1 native ip address dhcp ! interface FastEthernet0/0.2 description VOICE LAN INTERFACE encapsulation dot1Q 2 ip address 192.168.4.1 255.255.255.0 ! interface FastEthernet0/0.3 encapsulation dot1Q 3 ip address 192.168.5.1 255.255.255.0 ! ip forward-protocol nd ! ip http server ip http authentication local no ip http secure-server ip http path flash: ! access-list 1 remark SDM_ACL Category=2 access-list 1 permit 192.168.3.0 0.0.0.255 ! tftp-server flash:* tftp-server flash:P003-08-8-00.bin tftp-server flash:P0S3-08-8-00.sb2 tftp-server flash:P003-08-8-00.loads tftp-server flash:P003-08-8-00.sbn tftp-server flash:P00308000500.bin tftp-server flash:P00308000500.loads tftp-server flash:P00308000500.sb2 tftp-server flash:P00308000500.sbn ! control-plane ! ! ! voice-port 1/0/0 ! voice-port 1/0/1 ! voice-port 1/1/0 no vad timeouts call-disconnect 2 timeouts ringing infinity timeouts wait-release 5 ! voice-port 1/1/1 no vad timeouts call-disconnect 2 timeouts ringing infinity timeouts wait-release 5 ! ! ! ! ! dial-peer voice 101 voip description ** INCOMING CALL FROM TRUNK ** voice-class codec 1 session protocol sipv2 session target ipv4:184.72.227.214 incoming called-number .......... dtmf-relay rtp-nte no vad ! dial-peer voice 100 voip description ** OUTGOING SIP TRUNK CONNECTION ** destination-pattern 1.......... voice-class codec 1 session protocol sipv2 session target ipv4:184.72.227.214 dtmf-relay rtp-nte no vad ! dial-peer voice 200 pots destination-pattern 1500 port 1/1/0 no sip-register ! dial-peer voice 201 pots destination-pattern 1501 port 1/1/1 no sip-register ! ! sip-ua authentication username 1271a0da password 7 1517095D012F7E732A nat symmetric role active nat symmetric check-media-src no remote-party-id registrar ipv4:184.72.227.214 expires 3600 sip-server ipv4:184.72.227.214 ! ! telephony-service load 7960-7940 P003-08-8-00 max-ephones 2 max-dn 2 ip source-address 192.168.4.1 port 2000 auto assign 1 to 2 auto assign 1 to 10 type 7940 voicemail 1500 max-conferences 4 gain -6 web admin system name Admin password cisco dn-webedit time-webedit transfer-system full-consult create cnf-files version-stamp Jan 01 2002 00:00:00 ! ! ephone-dn 1 dual-line number 1000 call-forward busy 1500 call-forward noan 1500 timeout 18 ! ! ephone-dn 2 dual-line number 1001 call-forward busy 1500 call-forward noan 1500 timeout 18 ! ! ephone 1 no multicast-moh mac-address 000D.BDC0.265B keepalive 30 auxiliary 0 type 7940 button 1:1 ! ! ! ephone 2 no multicast-moh mac-address 0013.6086.0815 keepalive 30 auxiliary 0 type 7940 button 1:2 ! ! ! line con 0 exec-timeout 0 0 password cisco login line aux 0 line vty 0 4 password cisco login ! ntp server 71.40.126.157 ntp server 64.209.210.20 ntp server 192.168.3.24 ! end Router# Router#sh flash System flash directory: File Length Name/status 1 27006324 c2600-ipvoicek9-mz.124-15.T7.bin 2 2846504 cme-full-7.0.0.1.tar 3 18346 app-b-acd-2.1.0.0.ReadMe 4 24679 app-b-acd-2.1.0.0.tcl 5 24985 app-b-acd-2.1.2.2.tcl 6 18836 app-b-acd-2.1.2.2-ReadMe.TXT 7 18836 app-b-acd-aa-2.1.0.0.tcl 8 35485 app-b-acd-aa-2.1.2.2.tcl 9 75650 en_bacd_allagentsbusy.au 10 83291 en_bacd_disconnect.au 11 37952 en_bacd_invalidoption.au 12 496521 en_bacd_music_on_hold.au 13 123446 en_bacd_options_menu.au 14 42978 en_bacd_welcome.au 15 34794 en_bacd_xferto_operator.au 16 131470 CampusNight.png 17 80565 CiscoFountain.png 18 138278 Fountain.png 19 628 List.xml 20 109076 MorroRock.png 21 108087 NantucketFlowers.png 22 10820 TN-CampusNight.png 23 9657 TN-CiscoFountain.png 24 7953 TN-Fountain.png 25 7274 TN-MorroRock.png 26 9933 TN-NantucketFlowers.png 27 1029 CiscoLogo.gif 28 953 Delete.gif 29 864 downarrow.gif 30 4558 logohome.gif 31 1347 Plus.gif 32 843 sxiconad.gif 33 174 Tab.gif 34 870 uparrow.gif 35 3987 admin_user.html 36 6146 ephone_admin.html 37 3866 normal_user.html 38 2431 telephony_service.html 39 9968 xml-test.html 40 650596 admin_user.js 41 16344 dom.js 42 78428 normal_user.js 43 3412 xml.template 44 617 CME_GUI_README.TXT 45 129824 P00308000500.bin 46 458 P00308000500.loads 47 705536 P00308000500.sb2 48 130228 P00308000500.sbn 49 6148 .DS_Store 50 22542 CME-7-0-full-readme-v.1.0.txt 51 496521 music-on-hold.au 52 8160 Analog1.raw 53 8160 Analog2.raw 54 5280 AreYouThere.raw 55 5040 AreYouThereF.raw 56 8160 Bass.raw 57 12240 CallBack.raw 58 16040 Chime.raw 59 8160 Classic1.raw 60 16080 Classic2.raw 61 10800 ClockShop.raw 62 2823 DistinctiveRingList.xml 63 9600 Drums1.raw 64 13440 Drums2.raw 65 15840 FilmScore.raw 66 16080 HarpSynth.raw 67 8160 Jamaica.raw 68 16080 KotoEffect.raw 69 12720 MusicBox.raw 70 8160 Piano1.raw 71 15360 Piano2.raw 72 9360 Pop.raw 73 7200 Pulse1.raw 74 4000 Ring1.raw 75 4000 Ring2.raw 76 4000 Ring3.raw 77 4000 Ring4.raw 78 4000 Ring5.raw 79 4000 Ring6.raw 80 4000 Ring7.raw 81 495 RingList.xml 82 10800 Sax1.raw 83 14160 Sax2.raw 84 16080 Vibe.raw 85 15 OS79XX.TXT 86 962 SIP000DBDC0265B.cnf.xml 87 130952 P003-08-8-00.sbn 88 459 P0S3-08-8-00.loads 89 755912 P0S3-08-8-00.sb2 90 130548 P003-08-8-00.bin 91 962 SEP001360860815.cnf.xml [35108248 bytes used, 14699108 available, 49807356 total] 49152K bytes of processor board System flash (Read/Write) Router# Router#sh voice register all VOICE REGISTER GLOBAL ===================== CONFIG [Version=4.1(0)] ======================== Version 4.1(0) Mode is cme Max-pool is 24 Max-dn is 72 Source-address is 192.168.4.1 port 5060 Authenticate register Time-format is 12 Date-format is M/D/Y Time-zone is 5 Hold-alert is disabled Mwi stutter is disabled Mwi registration for full E.164 is disabled Forwarding local is enabled Dst auto adjust is enabled start at Apr week 1 day Sun time 02:00 stop at Oct week 8 day Sun time 02:00 Max redirect number is 5 Telnet Level: 0 Tftp path is system:/cme/sipphone Generate text file is disabled Tftp files are created, current syncinfo 0390373217450378 OS79XX.TXT is not created timeout interdigit 10 network-locale[0] US (This is the default network locale for this box) network-locale[1] US network-locale[2] US network-locale[3] US network-locale[4] US user-locale[0] US (This is the default user locale for this box) user-locale[1] US user-locale[2] US user-locale[3] US user-locale[4] US VOICE REGISTER DN ================= Dn Tag 1 Config: Number is 1000 Preference is 0 Huntstop is disabled Name SIP1 Auto answer is disabled Label is Test Phone VOICE REGISTER TEMPLATE ======================= VOICE REGISTER DIALPLAN ======================= VOICE REGISTER POOL =================== Pool Tag 1 Config: Mac address is 000D.BDC0.265B Type is 7940 Number list 1 : DN 1 Proxy Ip address is 0.0.0.0 DTMF Relay is enabled, rtp-nte Call Waiting is enabled DnD is disabled keep-conference is enabled username 3001 password 3001 service-control mechanism is not supported Dialpeers created: Statistics: Active registrations : 0 Total Registration Statistics Registration requests : 0 Registration success : 0 Registration failed : 0 unRegister requests : 0 unRegister success : 0 unRegister failed : 0 Router# From OS79XX.TXT file P003-08-8-00 From C:\TFTP-RT\SIP000DBDC0265B.cnf.xml -- From C:\TFTP-RT\SEP001360860815.cnf.xml -- - - - - 2000 192.168.4.1 {Jan 01 2002 00:00:00} P003-08-8-00 -English_United_States en United_States 0 http://192.168.4.1:80/localdirectory 0 -- 3804 0 - - - - - - 2000 192.168.4.1 {Jan 01 2002 00:00:00} P00307020400 -English_United_States en United_States 0 http://192.168.4.1:80/localdirectory 0 -- 3804 0
10-12-2012 01:58 PM
Thanks everyone for the input. I'm still working on the issue.
10-12-2012 11:18 PM
Did you checked the TFTP Server on the Phone settings?and Once your Phones are with static IP ensure that if the TFTP server (if not using DHCP) is correct on the Phone. Also the MAC: 000D.BDC0.265B is duplicated, that´s correct?
10-13-2012 12:19 AM
Please correct your option 150.
Now it's option 150 ip 192.168.3.22
From the rest of your config it looks as it should be option 150 ip 192.168.4.1
As previously noted you have the same MAC setup as both a SCCP and SIP CME phone. To which of these do you expect the phone to register?
For the SIP CME to work properly you should add bind statements under
voice service voip
sip
bind both .....
Also remember that every time you change anything in the SIP CME config you need to reissue the create profile command for the changes to be written to the cnf files on flash.
Please rate all useful posts.
10-14-2012 12:32 PM
Thanks. The SCCP is up and running. Now, the SIP phone is the issue. I'm not sure if the file that is in Bold should be the way it is or P0S3-08-8-00. I believe the problem starts here:
From OS79XX.TXT file P003-08-8-00 From C:\TFTP-RT\SIP000DBDC0265B.cnf.xml -- - - -
-- 2000 192.168.4.1 {Jan 01 2002 00:00:00} P003-08-8-00 -English_United_States en United_States 0 http://192.168.4.1:80/localdirectory 0 -- 3804 0 telephony-service load 7960-7940 P003-08-8-00 max-ephones 2 max-dn 2 ip source-address 192.168.4.1 port 2000 auto assign 1 to 2 auto assign 1 to 10 type 7940 voicemail 1500 max-conferences 4 gain -6 web admin system name Admin password cisco dn-webedit time-webedit transfer-system full-consult create cnf-files version-stamp Jan 01 2002 00:00:00 !
10-14-2012 12:51 PM
Do not use Cisco phones in SIP mode. Convert to SCCP firmware and everything will work fine.
11-13-2012 02:35 AM
Hi everybody, I am doing the CME initial config on 2901, along with 3560G switch, trying to registor a 7965 IP Phone,
The message displaying on the phone is unprovisioned , and while going to this state, it runs throgh Looking for
P00308010200.loads and it restarts and same procedure continues ....
When I do debug tftp events, I get the following messages,
TFTP: Looking for CTLSEPB4A4E329C55E.tlv
TFTP: Looking for ITLSEPB4A4E329C55E.tlv
TFTP: Looking for ITLFile.tlv
TFTP: Looking for SEPB4A4E329C55E.cnf.xml
TFTP: Looking for XMLDefault.cnf.xml
TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3272 for process 322
TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 322
TFTP: Looking for flash:/P00308010200.loads
Could anyone help me with this?
08-30-2013 04:55 PM
I've seen the unprovisioned message with SIP phones that were in Call
Manager but had no DN configured on the phone.
01-25-2019 06:40 AM
02-21-2020 03:34 AM
