PVDM3 with NM-HDV2 module
xzjleo2005
Hi guys,
We have a new 3945 running on IOS1 15.1.4M, it has one NM-HDV2-2T1/E1 and one PVDM3-64. I got following error message when I tried to create one E1 pri channel. We don't need any voice conferencing or transcode on this router. From the DSP calculator, it suggests me to use PVDM2-64 which should be sit on the NM-HDV2 module. Does it mean NM-HDV2 module can't use the PVDM3 resource on the router itself, or just NM-HDV2 module is not compatable with PVDM3?
% Not enough DSP resources available to configure pri-group on controller E1 4/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 2 extra 16 channel dsp(s) are required to create this voice port.
outcome from DSP calculator
Router: 3945
IOS: 15.1(4)M
DSP Modules Required:
PVDM2-64: 1
DSP Module Allocation:
Router Slot 4:60 Voice (94%) 4 Available (6%)
PVDM Slot 4/0: PVDM2-64
Call Volume Allocation:
LowMedHigh
Router Slot 4: NM-HDV2-2T1/E1(E1)60
Thanks. Leo
xzjleo2005
Found the answer, issue following command, then the NM module can share the DSP resouce on mother board. Thanks for your replies.
Conf t
voice-card X
dspfarm
dsp services dspfarm
16 Replies 16
ronpatel
Level 8
Level 8
HI
You cannot install PVDM3 modules directly on the  PVDM slots of an NM-HDV2, only the PVDM2s are supported by the NM-HDV2.  However, an NM-HDV2 that has no PVDMs installed at all can share PVDM3  DSP resources from the router motherboard PVDM slots across the chassis  backplane.
regards
Ronak Patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak, Thanks for your reply.
So the NM-HDV2 should be able to use the PVDM3 on mother board, but why did I get the error said not enough DSP when I created the PRI channel?
Leo
Hi Leo,
Have you installed it PVDM 3 on NM-HDV2 or on mother board?
Send the sh run of router if possible.
Ronak Patel
Please rate all informational posts also.
Hi Ronak,
PVDM3 is installed on mother board. Here is the show run and show inventory
Current configuration : 5510 bytes
! Last configuration change at 05:24:50 UTC Thu Aug 9 2012 by test
! NVRAM config last updated at 05:20:38 UTC Thu Aug 9 2012 by test
version 15.1
hostname SIP_GW
boot-start-marker
boot-end-marker
card type e1 4 1
logging buffered 51200 warnings
no aaa new-model
network-clock-participate slot 4
network-clock-select 1 E1 4/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2690548162
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2690548162
revocation-check none
rsakeypair TP-self-signed-2690548162
crypto pki certificate chain TP-self-signed-2690548162
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363930 35343831 3632301E 170D3132 30343235 31363534
  30315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36393035
  34383136 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B635 4A275C3C E80C90CB 53495BF4 99A13A97 92005BDF E77AD34D 1970C635
  2077FC55 C550FBCB B43E821A D2FD4281 BB558238 05B625C4 3BC3B9B3 BA05CA8F
  556E30A4 61085C50 FCFA9C3E 3D33E035 5004DDB2 3BFB5CC7 F38A3760 17E6F5D2
  A652CC4F 4558FED1 48CCE4B3 83C10899 4F5615B4 93C8BC9E 71479168 FA16B4CB
  256B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1444A6AD 93B188D9 D47857FB 09A4DC0D 160D811F E8301D06
  03551D0E 04160414 44A6AD93 B188D9D4 7857FB09 A4DC0D16 0D811FE8 300D0609
  2A864886 F70D0101 05050003 8181000A BF09B52F 0CA5774A AC52FEB0 AAE211A8
  07AE7293 FB148E9E F4A66D0A E9D1ECBD CE0B9F10 F3D57C87 1CCD9A76 3CDB14DE
  2E278DBD 0017F95C 6C11AA93 F52EF8D3 8BD75391 6D0DD09A 90043ADF B3EDD363
  BF638D8B 408D8C54 E6EEA1F5 793F882D 02569368 E09308E9 0368CC78 F9DED390
  682D5389 437C4BEB CE3A963E 2082B8
            quit
voice-card 0
voice-card 4
hw-module pvdm 0/0
hw-module sm 4
redundancy
controller E1 4/0
controller E1 4/1
clock source internal
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address x.x.x.x
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
SIP_GW#sh inven
SIP_GW#sh inventory
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
PID: CISCO3945-CHASSIS , VID: V02, SN:
NAME: "Cisco Services Performance Engine 150 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 150 for Cisco 3900 ISR"
PID: C3900-SPE150/K9   , VID: V05 , SN:
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN:
NAME: "Network Module Adapter for SM Slot on Slot 4", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN:
NAME: "High Density Voice2 Network module with on board two port interface  on Slot 4", DESCR: "High Density Voice2 Network module with on board two port interface "
PID: NM-HDV2-2T1/E1    , VID: V02 , SN:
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC       , VID: V03, SN:
paolo bevilacqua
What exactly are you trying to do? You don;t need the NM-HDV2-2T1/E1, but just a VWIC2 or VWIC3, and the PVDM3.
Hi Paolo,
The story was the vendor didn't have VWIC2 or VWIC3 in stock then gave us the NM-HDV2-2T1/E1. Does it mean NM-HDV2 can't use the PVDM resource on mother borad?
Thanks. Leo
There is no VWIC card on NM-HDV2-2T1/E1, we are trying to use the two E1 ports on NM module.
Any documents from Cisco explain this situation?
xzjleo2005
Conf t
voice-card X
dspfarm
Hi, I do have the same problem, I cant configure the PRI, may you please to share your configuration?
thanks,
Cesar.
Post your config and "sh diag".
Chris
Hi Deren
Here is the show run and show diag, I want the E1 NM to use the DSPs on the PVDM3 installed on the chasis instead of the PVDM2 on the NM. when I try to configure pri-group timeslots 1-31 this is the error message
% Not enough DSP resources available to configure pri-group on controller E1 1/0
% The remaining dsp resources are enough for 16 time slots.
% For current codec complexity, 1 extra 16 channel dsp(s) are required to create this voice port.
thanks in advance.
QUIRINAL_2911_GV#sh run
Building configuration...
Current configuration : 9445 bytes
version 15.2
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname QUIRINAL_2911_GV
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-4.M1.bin
boot-end-marker
card type e1 1 1
enable secret 4 ogRFA58sqtCqqOVz5pSvMHDQhNRAMsZX5zW5/gZcDgM
no aaa new-model
clock timezone GMT -5 0
network-clock-participate slot 1
ip domain name hocol.com.co
ip cef
no ipv6 cef
trunk group SALIDAPSTN
hunt-scheme random
trunk group SALIDACELULAR
hunt-scheme round-robin
crypto pki trustpoint TP-self-signed-2777551719
subject-name cn=IOS-Self-Signed-Certificate-2777551719
rsakeypair TP-self-signed-2777551719
crypto pki certificate chain TP-self-signed-2777551719
  69666963 6174652D 32373737 35353137 3139301E 170D3132 30383231 31343030
  34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37373735
  35313731 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A5F7 7D661C44 C155D12A CB2FD246 F669F657 A24F143C A6AB41EE 71823E3C
  EFCDAEA2 97A1E39D 4ED052D7 64BEF94C EA5AF48F C5AE0D8F 7BB47557 FE5FA561
  B2FA8A44 220CF926 5D3CD01B AF900F87 F6321E7A 827A7781 E7FB461F C50BD1BA
  E207219D 3E465DDE 427C4E73 EE74DEFC 2252B8EC 3B3A7DEE 6723198E 94C21F6E
  CEAD0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 141C6606 3008C488 91F9BEB1 55C215BA A1E6AAF7 C9301D06
  03551D0E 04160414 1C660630 08C48891 F9BEB155 C215BAA1 E6AAF7C9 300D0609
  2A864886 F70D0101 05050003 8181008E 31468D48 BEF4E6E0 B1A39F45 238268DD
  460FACEB D3FB5EA8 9D2C6902 D89DA6DA 9097D504 AFB1C38D 83B31B06 05E14C08
  B875727C 319C13B4 BFA5972B CEEDD0FE 6C4F27E1 8350C5AF C86FADE2 416D3334
  ED053918 56AB6648 BC8E6519 A80FF32B D1D662CA 378F0D98 727E8C67 0E87CFDF
  2F45133F AA34876E 29556CE2 E4D28D
        quit
voice-card 0
dspfarm
voice-card 1
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
sip
  bind control source-interface GigabitEthernet0/0.102
  bind media source-interface GigabitEthernet0/0.102
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 ilbc
voice class codec 1000
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g723ar63
codec preference 4 g723r63
codec preference 5 g711alaw
codec preference 6 g711ulaw
license udi pid CISCO2911/K9 sn FTX1634AJ22
hw-module pvdm 0/0
hw-module sm 1
username hocvoip privilege 15 secret 4 ogRFA58sqtCqqOVz5pSvMHDQhNRAMsZX5zW5/gZcDgM
redundancy
controller E1 1/0
shutdown
controller E1 1/1
no ip address
shutdown
no ip address
duplex full
speed 1000
ip http server
ip http access-class 23
ip route 0.0.0.0 0.0.0.0 10.4.2.1
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0
cptone CO
connection plar opx 6150
voice-port 0/0/1
cptone CO
connection plar opx 6119
voice-port 0/0/2
cptone CO
connection plar opx 6117
voice-port 0/0/3
cptone CO
connection plar opx 6151
voice-port 0/1/0
cptone CO
voice-port 0/1/1
voice-port 0/1/2
trunk-group SALIDAPSTN
supervisory disconnect dualtone mid-call
cptone CO
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 500
voice-port 0/1/3
cptone CO
voice-port 0/2/0
trunk-group SALIDACELULAR
cptone CO
caller-id enable
voice-port 0/2/1
cptone CO
voice-port 0/2/2
cptone CO
voice-port 0/2/3
cptone CO
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
sccp local GigabitEthernet0/0.102
sccp ccm 10.0.3.15 identifier 1 priority 1 version 7.0
sccp ccm 10.0.3.6 identifier 2 priority 2 version 7.0
sccp ccm 10.0.3.5 identifier 3 priority 3 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.102
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 3 register CFBNEIVA
associate profile 2 register MTPNEIVA729
associate profile 1 register MTPNEIVA711
associate profile 4 register TXCNEIVA
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions software 100
associate application SCCP
dspfarm profile 2 mtp
codec g729r8
dial-peer cor custom
name 1800
name local
name emergencia
name nacional
name celular
dial-peer cor list PermisoTotalSRST
member 1800
member local
member emergencia
member nacional
member celular
dial-peer cor list SalidaCelular
member celular
gatekeeper
shutdown
banner exec ^C
this session.
use.
^C
banner login ^C
CREDENTIALS
no username cisco
to use.
^C
line con 0
password 7 104D0617241A41195D077E656A647F7F
login
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
QUIRINAL_2911_GV# sh diag
Slot 0:
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 19 ports
        Port adapter is analyzed
        Port adapter insertion time 01:15:41 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC163161FQ
        Hardware Revision        : 1.0
        Part Number              : 73-11833-09
        Top Assy. Part Number    : 800-30797-06
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V06
        CLEI Code                : CMMJD00ARA
        Processor type           : C1
        Chassis Serial Number    : FTX1634AJ22
        Chassis MAC Address      : 6073.5cd2.bcf0
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 33 31 36 31 46 51 40
          0x10: 06 18 41 01 00 82 49 2E 39 09 C0 46 03 20 00 78
          0x20: 4D 06 42 41 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 36 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 44 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 54 58 31 36 33 34 41 4A 32 32
          0x60: C3 06 60 73 5C D2 BC F0 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0235-06
        PCB Serial Number        : AZS1628023J
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V04
        Product (FRU) Number     : PWR-2911-AC
        CLEI Code                :
        Board Revision           : A0
          0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 06 88 00 00 00
          0x10: 00 C1 8B 41 5A 53 31 36 32 38 30 32 33 4A 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 34 20 CB 8B 50 57
          0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 00 00 00 00 00
          0x40: 00 00 00 00 00 F3 00 59 41 00 BE 42 00 05 F8 00
          0x50: 50 01 F4 17 2B 02 EE 1A 7A 03 E8 1B 65 04 E2 1C
          0x60: 47 05 DC 1C C9 06 D6 1D A3 07 D0 1E 54 08 CA 1E
          0x70: E6 09 C4 1F 5C 0A BE 1F BF 0B B8 20 12 0D AC 20
          0x80: 92 0F A0 20 F0 11 94 21 38 13 88 21 6B 17 70 21
          0x90: AE 1B 58 21 D3 1F 40 21 E0 23 28 21 DE 27 10 22
          0xA0: 56 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        256-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11812-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC16316XL5
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-256
        Version Identifier       : V01
          0x00: 04 FF 40 05 DE 41 01 00 82 49 2E 24 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 33 31
          0x20: 36 58 4C 35 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 32 35 36 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-33585-01
        Board Revision           : D0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC16294SUV
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        CLEI Code                : CNUIAXJAAC
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 83 31 01
          0x10: 42 44 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 36 32 39 34 53 55 56 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 34 20
          0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 43 FF FF FF FF
        WIC Slot 1:
        Board Revision           : D0
        Fab Version              : 04
        PCB Serial Number        : FOC16294T3B
        RMA History              : 00
          0x20: 36 32 39 34 54 33 42 03 00 81 00 00 00 00 04 00
        WIC Slot 2:
        Board Revision           : D0
        Fab Version              : 04
        PCB Serial Number        : FOC16294TCW
        RMA History              : 00
          0x20: 36 32 39 34 54 43 57 03 00 81 00 00 00 00 04 00
        WIC Slot 3:
        3rd generation - FXS DID Voice daughter card (4 port)
        Top Assy. Part Number    : 800-33583-01
        Board Revision           : E0
        Fab Version              : 07
        PCB Serial Number        : FOC16304UNV
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        Version Identifier       : V03
        CLEI Code                : IPUIA6JRAC
        Longitudinal Calibration : 01 10 10 53 87 10 10 5B
                                   8C 10 10 82 98 10 10 A7
                                   7B
          0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 83 2F 01
          0x10: 42 45 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 36 33 30 34 55 4E 56 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
          0x50: 4A 52 41 43 D3 11 01 10 10 53 87 10 10 5B 8C 10
          0x60: 10 82 98 10 10 A7 7B FF FF FF FF FF FF FF FF FF
Slot 1:
        SM-NM-ADPTR
        Port Adapter is analyzed
        Port Adapter insertion time 01:15:41 ago
        PCB Serial Number        : FOC16311KE3
        Part Number              : 73-12434-04
        Top Assy. Part Number    : 800-32481-01
        Board Revision           : G0
        Fab Version              : 05
        RMA History              : 00
        Product (FRU) Number     : SM-NM-ADPTR
          0x00: 04 FF C1 8B 46 4F 43 31 36 33 31 31 4B 45 33 40
          0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
          0x20: E1 01 42 47 30 88 00 00 00 00 02 05 03 00 81 00
          0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
          0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
          0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        High Density Voice NM-HDV2-2T1/E1 Port adapter
        Port adapter insertion time 01:15:15 ago
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-22168-05
        Board Revision           : E0
        Fab Version              : 05
        PCB Serial Number        : FOC162737UL
        RMA History              : 00
        Fab Part Number          : 28-6126-05
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Product (FRU) Number     : NM-HDV2-2T1/E1
        Version Identifier       : V05
          0x00: 04 FF 40 03 DB 41 01 01 C0 46 03 20 00 56 98 05
          0x10: 42 45 30 88 00 00 00 00 02 05 C1 8B 46 4F 43 31
          0x20: 36 32 37 33 37 55 4C 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 17 EE 05 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 CB 8E 4E 4D 2D 48 44
          0x50: 56 32 2D 32 54 31 2F 45 31 89 56 30 35 20 D9 02
          0x60: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        FPGA revision:0x16C
        WIC Slot 1:
        HDV2 on board t1/e1 controller (2 port)
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8538-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC16313R00
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-16
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 36 33 31
          0x20: 33 52 30 30 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
QUIRINAL_2911_GV#
You need to remove the PVDM2-16 from the HDV card in order to use the PVDM3 from motherboard. Per:
Q. Are the PVDM3 modules supported in a NM-HDV2?
A. No. You cannot install PVDM3 modules directly on the PVDM slots of an NM-HDV2, only the PVDM2s are supported by the NM-HDV2. However, an NM-HDV2 that has no PVDMs installed at all can share PVDM3 DSP resources from the router motherboard PVDM slots across the chassis backplane.
http://www.cisco.com/en/US/prod/collateral/modules/ps3115/qa_c67_553073_ps10537_Products_Q_and_A_Item.html
As it stands the router is trying to allocate the PVDM2-16 first which is not enough for PVDMs.
HTH, pleae rate all useful posts!
Chris
Cesar,
You can also send the output of
show voice dsp group all...
This will let us know what resources you have left on your PVDM3-256. As Chris, you need to remove the PVDM2-16, but you also need to know what you have left on the PVDM3-256. So send the output of that command
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
