11-29-2019 02:58 AM - edited 11-29-2019 02:58 AM
Hi.
I have configured Software MTPs in Cisco IOS 4331 and I cant register them.
IOS: 16.9.4
Router: ISR4331/K9
sccp local GigabitEthernet0/0
sccp ccm 10.0.180.41 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register G711u-SW-SCCP
switchover method immediate
switchback method immediate
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions software 50
associate application SCCP
telephony-service
sdspfarm units 10
sdspfarm tag 6 G711u-SW-SCCP
no auto-reg-ephone
max-ephones 20
max-dn 20
ip source-address 10.0.180.41 port 2000
show sccp
MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: NOT_REGIS_WITH_CCM
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 100, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
The above configuration is already configured in a CISCO3925-CHASSIS without any problems.
Also other dspfarm profiles are registered successfully.
11-29-2019 06:13 AM
Hope this isn't a silly question, but when you say "The above configuration is already configured in a CISCO3925-CHASSIS without any problems." can you confirm that you don't mean literally the same configuration, but that each device uses a unique name for its profile.
11-30-2019 01:09 AM
Just realised this is CME not CUCM. So in that case of course the device name is only locally significant. Under telephony-service, does the tag number in "sdspfarm tag" need to match the dspfarm profile number?
11-30-2019 07:20 AM
I don't think the tag needs to match, just the name. Here is CME admin guide which includes MTP example for reference:
Have you tried issuing "no sccp", "sccp"? What does debug sccp show?
12-02-2019 06:39 AM
Below is the correct configuration. The sdspfarm tag was a typo here.
Attached is the "debug sccp all" output.
sccp
sccp ccm group 1
codec g711ulaw
telephony-service
sdspfarm units 10
sdspfarm tag 1 G711u-SW-SCCP
no auto-reg-ephone
max-ephones 20
max-dn 20
VG1(config)#do show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0/0
IPv4 Address: 10.0.180.41
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.0.180.41, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
