02-18-2020 08:36 AM
CUCM System version: 11.5.1.15900-18
Phones 8811 firmware sip88xx.12-7-1-0001-393
Users in two different buildings are reporting their phones are beeping and flashing a message on the phone display telling them they are being too loud. Initially I thought they were talking about paging and that someone was playing jokes. But the message displays on the phone screen, the only sound is a beeping tone.
02-18-2020 08:41 AM
New feature on the 12.7 FW, review the RN
02-18-2020 09:10 AM
I found it. Is there a way to turn that off in Call Manager or does it have to be done from the phone?
02-18-2020 09:13 AM - edited 02-18-2020 09:20 AM
You can definitely disable it via the phone settings, but only Via the device menu and not centrally via the CUCM.
George
02-18-2020 01:29 PM
Check out CSCvt04894.
NOTE: This is a "feature request".
06-30-2020 03:43 PM
FYI, CSCvt04894 is now implemented in v12.8.1 and disabled by default.
02-18-2020 08:45 AM
This is "Lower your Voice" Notification and it was introduced on firmware 12.7. This is a feature that could be disabled.
George
02-24-2020 11:39 AM
is there a way to send curl or xml commands to disable this feature remotely?
02-24-2020 12:28 PM
3rd party apps like Variphy (probably others) can run macro's to replicate the button presses necessary to disable this feature at a device level. You can run it against device types, devices pools...it can also be scheduled to run off hours.
This is what I just finished doing for about 2,500 phones.
