Toll fraud and we unable to find any details in CDR Called Party No
Hi All,
Happy New year!!!
We have call manager System version: 7.1.5.31900-3 and voice gateway H323. The telco send the reports and saying that from our PRI used some high risk county calls. also  High usage of ILD calls to spcific county and call duration is very huge....
As per the Telco the calls are made from our pilot number e.g. A party -223099xxxxx and B Party 00974444xxxx.
based on the Telco B-party number and timestamp we have collected CDR logs, from CDR logs we unable to match B-party numbers...
we have created route pattern and blocked spiciifc country calls also, still we got some calls used those PRI...
please advise me, if any possible using  3rd party SIP phones to our voicegateway and making calls or any way to hacking the VG.
please any one advise your inputs on the same....
Thanks & Regards,
Naveen.S
11 Replies 11
Bhunt 410
If you are using H323 and only blocked it on the CUCM, you still have the gateway to worry about since you have a peer to peer setup.  Also you can setup a syslog server(kiwi) comes to mind and run debugs and log them to your desktop so you can see them when you come to work or VPN from home and take a look.
I'm not sure of how they are getting out at this point I've seen tool fruad from just fowarding numbers, to people getting dial tone on unity.  As for right now you should be blocking calls to that location at the provider level, and setup  access-list to only allow VOIP traffic to come from your subnets on to your gateway.
HI,
I am naveen's colleague.
We have been monitoring the debugs. Though I have not done it personally. My team has reported that there has not been anything in the debug.
However I have enabled the Traces from CUCM on the Gateways. Will that help.
You might need to concentrate on the gateways rather than the call manager, as generally PSTN gateway is the most vulnerable part being exposed to the outside world. Toll fraud may occur if you're generating secondary dial tone on any of your PRI lines. That should be the first thing to check.  This kind of traffic is not passing thru call managers, so it doesn't generate any logs or CDRs.
As a reference, you can refer to this document, even though it's titled for CME it covers the relevant parts:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a00809dc487.shtml
Also you can immediately check show isdn history to check the traffic (default 15 minutes) or
use "show call history voice brief"
You can increase the history size using the commands:
dial-control-mib retain-timer 2880 (in minutes)
dial-control-mib max-size 1200 (number of records)
As tol fraud seems be an issue here I suggest that you read
this link and upgrade your IOS to at least 15.1.T2
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
Implement the anti toll fraud config (very simple) this will allow
outbound calls only to set up from your call managers and will
block all other SIP or H323 call attempts
E.g.
voice service voip
ip address trusted list
  ipv4 10.10.10.100 255.255.255.255
  ipv4 10.10.10.200 255.255.255.255
Where the 2 Ip addresses are examples of
Call Manager servers and no other addresses will be trusted
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Possibly the fraud does not come from network, but from PSTN; where they find a DID that gives dial-tone, and use it as a re-dialer.
Hi Thanks for the excellent suggestion.
Getting aproval for upgrade is going to take some time, but we will try to push for this.
You may not need the upgrade. The newer IOS code has "direct-inward-dial" as a default on PRIs, which causes the router to look for an outbound dial-peer before it will accept the inbound call. (Preventing secondary dial-tone.) However, that command is available on earlier versions of IOS  and implementing it may help with the problem.
Along with that, of course, setting up the trust list for VoIP inbound signaling is a must as well as @acampbell noted for public-facing routers.
jking2685
Hi Naveen / Rohan,
Are your voicemail ports restricted from dialling out?http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/security/guide/8xcucsec020.html
Do you allow all users to dial international calls? Maybe setup some CSS and partitions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmsys/a03ptcss.pdf
What about time of day routing?http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
You could also enable the CDR reports on the UCM and check for the calls.
A basic reporting interface is provided by Cisco or you could use a 3rd party tool to collect the data and run reports. Many are listed on the Developer portal using the following search terms:
Call Logging (Certified products)
http://developer.cisco.com/web/partner/search?text=call logging&technologyIds=a0G40000000xlnlEAA&subTechnologyIds=a0K40000000eHsEEAU&technologyProductIds=a0I40000000ycykEAA&partnerProductFamilies=Call Accounting and Billing&certified=Yes&onCiscoPriceList=All&portfolioPartner=All
Call Accounting (Certified products)
http://developer.cisco.com/web/partner/search?text=call accounting&technologyIds=a0G40000000xlnlEAA&subTechnologyIds=a0K40000000eHsEEAU&technologyProductIds=a0I40000000ycykEAA&partnerProductFamilies=Call Accounting and Billing&certified=Yes&onCiscoPr...
Our TIM Plus and TIM Enterprise products have built in toll fraud with customisable alarms, AXL directory integration and unlimited display boards included as standard.
Were CDR's enabled on all your UCM node(s) before you had the toll fraud calls? If so you could run your historic data through our product and see what calls were reported by the UCM and setup alarms for any future calls.
You can arrange for a free trial via our Cisco microsite www.tri-line.com/cisco
TIM Enterprise overview video:
AXL integration:
Like the others suggested if your not seeing the calls on the call manager then the gateway itself is placing the calls.  Does your gateway have a public IP address?
you can do a show udp on the voice gateway and see if any forgen hosts are are connected. Especially look to see what is using ports 5060 and 5061.
If these udp ports are open a third party can use SIP to place calls to your gateway and as long as it matches a dial-peer it will palace the call for them.  A 9T dial peer will let them use your gateway to dial out any where.
If you have a foriegn host using these ports you can use an ACL to deny access on these ports.
Just to add the James' (+5) comments, the most common instance I see of toll fraud is where someone has connected their gateway to the Internet, but has not configured an inbound ACL.
If you want to see how often gateways are targetted to see if their H.323 or SIP ports are open, create an ACL blocking TCP/1720, UDP/5060 and TCP/5060 and log it.
ip access-list ext inbound
deny udp any any eq 5060 log
deny tcp any any eq 5060 log
deny tcp any any eq 1720 log
permit ip any any
interface g0/0
desc outside interface
ip access-group inbound in
Note that you'll need to tailor this ACL to reflect your actual requirements, however you will very quickly see matches on the rules blocking SIP and H.323. IOS version 12.4 and earlier will automatically place H323 calls unless you specifically block them.
An example for a router that has been up for less than a week:
Rtr#show ip access-list inboundfilters
Extended IP access list inboundfilters
    1 deny tcp any any eq 5060 log (18 matches)
    2 deny tcp any any eq 1720 log (18 matches)
    3 deny udp any any eq 5060 log (1487 matches)
HTH. Barry
I am seeing a bizarre issue on my router. It is an H323 gateway with 1 PRI and no SIP trunk. There are continuous call attempts, see attached the config of the router. In Active calls, it shows SIP call legs, but there is no SIP enabled anywhere.
Active Calls:
Telephony call-legs: 1
SIP call-legs: 4
H323 call-legs: 1
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 6
29C3 : 194775 937775290ms.1 +3070 pid:100 Answer 7807330020 active
 dur 00:00:19 tx:989/158240 rx:987/157920
 IP 10.101.138.5:23708 SRTP: off rtt:0ms pl:17330/0ms lost:0/0/0 delay:55/55/65ms g711ulaw TextRelay: off
 media inactive detected:n media contrl rcvd:n/a timestamp:n/a
 long duration call detected:n long duration call duration:n/a timestamp:n/a
29C3 : 194776 937775410ms.1 +2950 pid:4 Originate 812607687771 active
 dur 00:00:19 tx:991/158560 rx:987/165816
 Tele 0/0/0:23 (194776) [0/0/0.23] tx:19820/19820/0ms g711ulaw noise:-61 acom:0  i/0:-19/-68 dBm
1DD2 : 194777 937781520ms.1 +-1 pid:0 Answer 123205 connecting
 dur 00:00:00 tx:0/0 rx:0/0
 IP 192.168.1.83:25282 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
1DD7 : 194778 937787120ms.1 +-1 pid:0 Answer 11015 connecting
1DDC : 194779 937788200ms.1 +-1 pid:0 Answer 6101 connecting
1DE1 : 194780 937796380ms.1 +-1 pid:0 Answer 2001 connecting
 IP 216.244.65.186:5076 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
SIP call-legs: 4
H323 call-legs: 1
SCCP call-legs: 0
Total call-legs: 6
