Ucnx upgrade failed from 8.5 to 8.6 on VMWare
rajesh.kumar
Level 4
Level 4
Unity Connection upgrade fails from 8.5.1.10000-26 to 8.6.2.20000-2
ISO image used is : UCSInstall_UCOS_UNRST_8.6.2.20000-2.sgn.iso
System specification
System version: 8.5.1.10000-26
VMware Installation: 2 vCPU Intel(R) Xeon(R) CPU           E5640  @ 2.67GHz, disk 1: 200Gbytes, 6144Mbytes RAM
Attached upgrade logs
Pls. suggest, what could be wrong?
2 Accepted Solutions
ronpatel
Level 8
Level 8
You will have to use COP files before upgrading.
ciscocm.refresh_upgrade_v1.1.cop.sgn
This file is same for UCM, Unity Connection, CUCMBE5k (and IME).
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Rob Huffman
Hi Rajesh,
You are most correct my friend
The .cop and install files are identical between Unity Connection
and CUCM. And the "refresh" requirements to move to 8.6 are identical as well.
Cheers!
Rob
ronpatel
Level 8
Level 8
Thanks a lot,
COP file is same for CUCM and Ucnx
Even upgrade from 8.5 to 8.6 version is also same for CUCM and Ucnx?
ie UCSInstall_UCOS_UNRST_8.6.2.20000-2.sgn.iso ?
Rgds
Rajesh
Rob Huffman
Hi Rajesh,
Cheers!
Rob
Dear Rob
After upgrading this patch, Ucnx upgrade we through well.
But for CallManager, even after upgrade also, upgrade fails inbetween.
Publisher is upgraded. But subscriber upgrade is failed two times.
Is there any other posibilites, why upgrade from 8.5 to 8.6 failing ?
Here I have attached the logs I got during upgrade, two failed upgrade log files attached.
Current version of CUCM-SUB is 8.5.1.10000-26 (running on VMWare)
upgrading to 8.6.2.20000-2
After approx. 90 minutes during upgrade it endup with error.
admin:show version ac
admin:show version active
Active Master Version: 8.5.1.10000-26
Active Version Installed Software Options:
admin:show version in
admin:show version inactive
No Inactive side available
Pls. advice.
Rgds
Rajesh
Message was edited by: RAJESH KUMAR
