Unity Connection 10.5.2 integration with 2 CUCM clusters
Jagadish2
We got an requirement for having one cuc 10.5.2 and that needs to be integrated with 2 different CUCM Clusters. Is this possible by have 2 different Phone integrations in CUC ??
Any best steps to do so.. Please suggest.
Jagadish
Here is the guide for multiple integrations for Unity Connection 11.x. The steps are essentially the same for 10.x
Multiple Phone System Integration Guide for Cisco Unity Connection Release 11.x
Maren
Yes its possible that one CUC can serve VM service for two CUCM clusters.
Response Signature
If both CUCM use same extension range, I believe that,  you may need to consider  CUC partition and search space.
Response Signature
Yes that’s absolutely possible. Just follow the integration steps in the documentation for CUC two times and use one of the CMs each time. Not more to it than that.
Response Signature
Maren
