Upgrade CUCM 8.5 to 8.6
Hi to all,
 I have a customer who would like to upgrade its CUCM from 8.5 to 8.6 (I don't know why he wants it), somebody knows when I do a upgrade from CUCM 8.5 to 8.6, all the configuration remains and is valid for the new version? Is a minor upgrade?? How many improvements have the 8.6 about 8.5 version??
In the cisco site, all documentation for the 8.5 version is the same than the 8.6 version, but I didn't find any documentation for this purpose. All the documentation that I can find is about the upgrade from 4.X or 3.X version.
Somebody can help me?? If you could leave me a link to a document or website I would thank you a lot.
Thanks to all!!
2 Accepted Solutions
Manish Gogna
Yes, this upgrade does not result in any data loss. For information about new features and changes introduced in cucm 8.6, check the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/8_6_2/delta/delta862.html
Manish
Please refer to the below link:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/8_6_2/cucm-rel_notes-862a.html#pgfId-1944944
Venkatesh
7 Replies 7
Aman Soi
Hi Babi,
it would be a minor upgrade with  no requirement for licenses.Further, the configuration would remain intact after u do minor/major upgrade.
regds,
aman
Hi Babi,
you can refer the software compatibility matrix for upgrade paths or cop files if required.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
[+5] to Aok for more detailed explaination.
regds,
aman
Manish Gogna
Manish
Venkatesh
Thanks, you help me a lot!!!!
I wasn't able to find any documents....
Thanks a lot!!!
Babi,
Please note that even though this is a minor upgrade, this is a refresh upgrade and leads to long down time due to several server reboots. Recommended practice for this is as follows
  • Perform a DRS back up before upgrade
  • Track console of server to monitor progress of upgrade – IP KVM, HP ILO, or IBM RSA
  • Install the latest COP (ciscocm.refresh_upgrade_v1.1.cop.sgn) file to allow for successful upgrade and limit switch version after upgrade
  • To minimize downtime, upgrade Publisher or first node until completion and then upgrade first set of Subscribers or secondary nodes while leaving some nodes performing call processing
  • Select automatic Switchover to the new version
Please rate all useful posts
