01-29-2009 11:25 AM - edited 03-15-2019 03:51 PM
Anyone know if VIC3-4FXS/DID is supported MGCP Controlled VIC Endpoint with Call Manager version?
01-29-2009 11:46 AM
Yes, it is.
01-29-2009 11:48 AM
particular call manager version/SR required?
01-29-2009 12:26 PM
I don't think there is a requirement. CM doesn't really know what exact kind of card it is.
01-29-2009 12:39 PM
Actually with MGCP Controlled Endpoints on a gateway it does have to be supported specifically in Call Manager usually but the good news is I just referenced a CM 6.1(2) and the VIC3-4FXS/DID is in the list.
05-06-2009 08:32 AM
Do you have a list or did you just look at the Call Manager. I am trying to figure out if a VIC3-2FXS/DID is supported in Call manager 4.2(3)SR3? Thanks in advance
05-07-2009 05:56 AM
No unfortunately I never was never able to find a compatibility matrix. I just saw it under the particular CM Version that I was working on at the time.
05-07-2009 07:20 AM
I have a TAC case opened. They are researching the version.
06-04-2009 06:34 AM
Just wanted to follow up on this, did you ever get a good compatibility matrix or anything for hardware to call manager software or any other good resource for this?
09-09-2009 08:17 AM
Hi Thomuff.
The TAC says to you what version support the VIC3-4FXS? My CCM is 4.1.x
Peterson
09-09-2009 02:44 PM
I'm having working VIC3-4FXS with MGCP (IOS 12.4.24T1) and CCM 7.0.2b
MC
