Bookmark
Subscribe
38274
SIP 503 Service Unavailable Unable to find a device handler for the request received on port
I have a communication problem because I try to dial from a CUCM to another CUCM using a SIP TRUNK, there is a route pattern in both, however the call is not completed, but from the other CUCM if the call is made.
This is what the log shows me:
SENDER: [SIPTrunkMToCUCMTelepresense] 10.10.50.220
GUID: 9bc5ea00-a991a20d-15602a-421a8c0@192.168.33.2
MSG_LABEL: 503 Service Unavailable
RECEIVER: 192.168.33.2
MAC_ADDRESS: SIPTrunkMToCUCMTelepresense
MSGTAG: 18898445
MSG_TYPE: UCM_CTRACE
CORRELATIONID: 2,100,14,173974.3^10.10.50.220^*
TIMESTAMP: 2018/03/02 13:12:13.549
Detailed Sip Message
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/TCP 192.168.33.2:5060;branch=z9hG4bK1a699412078b62
From: " 70078" < sip:70078@192.168.33.2> ;tag=6726498~39f5e661-6c3c-f206-ade4-f81e64c66686-41465062
To: < sip:41001@10.10.50.220> ;tag=1857616815
Date: Fri, 02 Mar 2018 19:14:27 GMT
Call-ID: 9bc5ea00-a991a20d-15602a-421a8c0@192.168.33.2
CSeq: 101 INVITE
Allow-Events: presence
Warning: 399 CUCM9 " Unable to find a device handler for the request received on port 43953 from 192.168.33.2"
Content-Length: 0
Message In Log File
2018/03/02 13:12:13.524|SIPL|0|TCP|IN|192.168.33.2|5060|SEP94D4690D1554|192.168.32.31|53068|2,100,14,173168.247^192.168.32.31^*|18898439|94d4690d-1554014b-19fed024-273cb4d5@192.168.32.31|INVITE
2018/03/02 13:12:13.525|SIPL|0|TCP|OUT|192.168.33.2|5060|SEP94D4690D1554|192.168.32.31|53068|2,100,14,173168.247^192.168.32.31^*|18898440|94d4690d-1554014b-19fed024-273cb4d5@192.168.32.31|100 Trying
2018/03/02 13:12:13.531|CC|SETUP|41465061|41465062|70078|41001|41001
2018/03/02 13:12:13.538|CC|OFFERED|41465061|41465062|70078|41001|41001|SEP94D4690D1554|SIPTrunkMToCUCMTelepresense
2018/03/02 13:12:13.546|SIPT|41465062|TCP|OUT|192.168.33.2|5060|SIPTrunkMToCUCMTelepresense|10.10.50.220|5060|2,100,13,36399.1^*^*|18898443|9bc5ea00-a991a20d-15602a-421a8c0@192.168.33.2|INVITE
2018/03/02 13:12:13.549|SIPT|41465062|TCP|IN|192.168.33.4|5060|SIPTrunkMToCUCMTelepresense|10.10.50.220|5060|2,100,14,173974.2^10.10.50.220^*|18898444|9bc5ea00-a991a20d-15602a-421a8c0@192.168.33.2|100 Trying
2018/03/02 13:12:13.549|SIPT|41465062|TCP|IN|192.168.33.2|5060|SIPTrunkMToCUCMTelepresense|10.10.50.220|5060|2,100,14,173974.3^10.10.50.220^*|18898445|9bc5ea00-a991a20d-15602a-421a8c0@192.168.33.2|503 Service Unavailable
2018/03/02 13:12:13.550|SIPT|41465062|TCP|OUT|192.168.33.2|5060|SIPTrunkMToCUCMTelepresense|10.10.50.220|5060|2,100,14,173974.3^10.10.50.220^*|18898446|9bc5ea00-a991a20d-15602a-421a8c0@192.168.33.2|ACK
2018/03/02 13:12:13.554|SIPL|41465061|TCP|OUT|192.168.33.2|5060|SEP94D4690D1554|192.168.32.31|53068|2,100,14,173974.3^10.10.50.232^*|18898447|94d4690d-1554014b-19fed024-273cb4d5@192.168.32.31|503 Service Unavailable
2018/03/02 13:12:13.558|SIPL|41465061|TCP|IN|192.168.33.2|5060|SEP94D4690D1554|192.168.32.31|53068|2,100,14,173168.248^192.168.32.31^*|18898448|94d4690d-1554014b-19fed024-273cb4d5@192.168.32.31|ACK
2018/03/02 13:12:13.559|CC|REJECT|41465061|41465062|70078|41001|41001|1459617833
Someone with a similar problem
7 Replies 7
Jonathan Unger
Level 7
Level 7
Hi There,
When a 503 service unavailable message comes back from CUCM, it is usually due to one of the following reasons:
  1. After the SIP trunk was created on CUCM, it was not reset
  2. The IP address inside of the SIP trunk in CUCM was not configured properly. The IP address on the SIP trunk in CUCM must match the IP address of the CUCM server on the other side in your case.
Can you try resetting the SIP trunks on both sides and checking the IP addresses and ports configured in the SIP trunks as well?
Hope this helps!
- Jon
Hello
If you have in both SIP Trunk the IP addresses of the CUCM, and of a CUCM if you can call us, but from another CUCM we can not.
Dennis Mink
this issue was raised before, did you verify:
https://supportforums.cisco.com/t5/other-collaboration-voice-and/sip-2-0-503-service-unavailable/td-p/1250555
cheers
Please remember to rate useful posts, by clicking on the stars below.
Chris Deren
Is "route on all nodes" checked on both SIP trunks and Route Lists?
It is works for me, thanks
infrateam
Level 4
Level 4
Did you fix this? I have this problem too.
tgaur
1) check the destination of the siptrunk of the destination cluster. the ip from which the invite is coming should be trusted by the remote cluster.
2) check the sip security profile and check for the port it can accept and on which port you receive the invite.
3) is there any inspection enabled between the cluster? if so disable it for SIP traffic.
