Physical Security
Cisco CyberSecurity
Hey everyone! I’m trying to connect to the Wi-Fi at Cromwell High School and could really use a hand. Does anyone happen to know the username and password for cps-wireless or the password for cps-guest? I would greatly appreciate it. Thanks a ton!
mirjetapinky by Community Member
  • 1389 Views
  • 2 replies
I am deploying a virtual firewall solution in a cloud environment and would like advice.I am renting a virtual machine with the following configuration:16 vCPUs32 GB RAM1,200 GB SSD storage1 public IPv4 address300 Mbps internet bandwidth Which device...
thait01 by Frequent Visitor
  • 1008 Views
  • 3 replies
Hello Together,we installed a new FMC in Azure for some testings. Now I stuck because how can I add a physical FTD to this FMC in Azure Cloud? I tried it form Inside an office with the normal command "configure manager add ....", but it won´t work. T...
ralpho1 by Level 1
  • 1708 Views
  • 3 replies
Hi AllWe are looking at replacing our ASA5545X with a new firewall.We have already replaced a smaller model with a Firepower managed in cdFMC within CDO, its working well.What are peoples thoughts, stay with the ASA code or move to Firepower?Also, th...
I have replaced 10 ISE servers (SNS-3595-K9 with SNS-3655-K9) and need to secure wipe the old hard drives before disposal. How can I access the hard drives on a SNS-3595 chassis to run a secure wipe application? __PRESENT __PRESENT
