Webex for Developers
We're thrilled to announce that the Webex for Developers Community forum has expanded to include dedicated topics for Webex Contact Center APIs and integrations! We encourage all Webex Contact Center developers to utilize this forum to engage in disc...
philbell by Cisco Employee
  • 2765 Views
  • 1 replies
  • 3 Helpful votes
Hello,I have some questions about the guest tokens you can create using this API: https://developer.webex.com/admin/docs/api/v1/guest-management/create-a-guestIs there a rate limit on the number of tokens you can create using one access token? Also i...
Hi,The WebEx Calling - Call Controls description is currently incomplete and needs to be updated. We've found that the admin auth token 'spark-admin' scopes may need to be used, but are not mentioned in: https://developer.webex.com/calling/docs/api/v...
Hello,I'm attempting to add abandoned call counts to my progressive profiles. They are currently reporting "None" even when their are abandoned calls to the calling party. Looking back through the journey I don't see any abandoned call events. Should...
jonmmyers by Frequent Visitor
  • 639 Views
  • 2 replies
