CSPC 2.8.1.4 Upload Failed - Internal Server Error
wambari
Setting up new installation and getting the following Error on upload:
"Internal Server Error"
Have generated the Certificate a number of times and checked firewall rules to permit all Cisco IPs required for upload of data.
Could this be a bug as I have never had a challenge with CSPC before.
Your help troubleshooting this appreciated.
Ernest.
Ended up doing a complete re-install and skipped the update option to latest version.
Was able to upload successfully.
Thanks for the support.
W.
7 Replies 7
jumin
Hey wambari,
Are you receiving this error with the first upload from the CSPC?  Please provide the results of
ping tools.cisco.com
telnet tools.cisco.com 443
wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
openssl s_client -connect concsoweb-prd.cisco.com:443
Justin
Hi Justin,
Yes,this is a first attempt at upload after fresh installation.
Have sent you the outputs via Direct Message.
Your support appreciated.
Wambari
jumin
Hey wambari,
I didn't seem to receive a message.  Please try once more via hovering over my username and selecting 'Send Message'.
Justin
Justin,
Re-sent.
W.
adias
Please under your the banner Menu of the application --> help--> about--> please send us the screenshot of the server details..
W.
