Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3057 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4636 Views
  • 1 replies
  • 16 Helpful votes
Hi Guys,I am using around 5 sg300's with a lot of Crestron AV kit / touchscreens. About once every couple of months the touchscreens all stop responding. We have found that a reboot of the Cisco switch attached to the touchscreens brings everything b...
phcjpp123 by Level 1
  • 968 Views
  • 2 replies
For having 3 settopboxes for iptv I have setup vlan 3 for iptv.IGMP snooping is enabled for vlan 3 with the default settings and port 5 (incoming iptv) is enabled as IGMP Mrouter.In the multicast forwarding table vlan 3 is set to filter unregistered....
Hi,I'm  setting up an SG-300 and would like to block some traffic with ACLs.  While I'm  new to cisco products, I was able to easily setup an IP based ACL to restrict  certain IPs from accessing specific ports, but my problem is with applying these ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
