We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
350
(7) -
350X
(4) -
550X
(2) -
Branch Router
(3) -
Buying Recommendation
(8) -
Catalyst Switch
(1) -
CBS Switch
(1) -
CBS110
(1) -
CBS220
(3) -
cbs250
(6) -
CBS350
(22) -
Cisco Bugs
(2) -
Cisco Business Dashboard
(1) -
Cisco Cafe
(1) -
Cisco Software
(1) -
Community Feedback Forum
(2) -
Community Ideas
(5) -
Configuration
(1) -
CSC Content with No Valid Community to Post
(1) -
Device Admin
(1) -
Intent Based Networking
(1) -
LAN Switching
(72) -
Network Management
(30) -
Other Network
(1) -
Other Networking
(2) -
Other Routing
(3) -
Other SD-WAN
(1) -
Other Security Topics
(1) -
Other Switches
(55) -
Other Switching
(21) -
Physical Security
(1) -
Routing Protocols
(1) -
Small Business Network and Smart Storage
(1) -
Small Business Routers
(1) -
Small Business Support
(3) -
Small Business Support Service
(1) -
Small Business Switches
(6,761) -
SmartTV
(1) -
switch
(2) -
WAN
(1)
- « Previous « Previous
- Next » Next »
(Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Catalyst 1200 & 1300 Hardware Install...
Hi folks,I am new to the whole VLAN thing, so excuse my ignorance. I have successfully set up a VLAN on my primary switch which is an SGE2010. I have 3 other switches is other buildings connected in series. The next in line is another SGE2010 and...
Usually with servers and all I'm gung ho about updating firmware as it fixes problems. But really never mucked too much with switch firmware. We just got a SG200-18 new from Dell as they sell Cisco stuff. It came with 1.0.0.19 firmware version. But I...
Resolved! ip igmp snooping querier?
i've been reading these forums and noticed that lot of people have problems with configuring multicast. basicly, problems are flooding bandwidth, no querier, confusing pim router configuration ...also, ive seen some promisses from tehnical stuff that...
Hi,Is also the SR2024T-EU EOL?
Resolved! SPS224G4 pinouts
Does anyone have the pinouts for making a serail cable to connect from a pc to the LINKSYS SPS224G4 Switch? Thanks!
I recently purchased a SF 100D 5 port switch, that is frustrating me. I currently have a New dell PC connected through a wall jack to an existing router, and wanted to add an ethernet printer. When I connect everything to the switch, I can only ge...
We just purchased 8 managed switches POE to swap out our existing in preparation for our new phone system. We installed them all after configuring with static IP. Deployed... and all but two work fine. Can someone assist with tips for troubleshoot...
Hi AllI have a SF 200-24P Cisco switch that seems to be rebooting constantly, When i connect it to mains power it seems to go through a startup cycle, in this order - i have tried this with no network devices attached and the same thing happens1. Fa...
We recently purchased a SF 300-48P to replace a Layer 3 3Com switch that died. I've sucessfully put the switch into Layer 3 mode and assigned ip addresses to each of the VLANs but I cannot figure out how to implement routes for those. Here's some inf...
Hi,Mgmt Vlan 1 (default)Data VLan 10 (with access to internet)Is there a way to have a PC attached to a SG300 switch such that it can both access Vlan 10 for data and Vlan 1 for managment ?The PC's port clearly needs to be untagged PVID on vlan 10. I...
Hi,I have a recently purchased 28 port SG300 switch. Everything is working well. Unfortunately there is so much traffic flying around that a 10MB half duplex device is struggling to function as it is overloaded. Removing some of the sources of traffi...
I'm sure this is something very basic, but it has me a bit stumpedThis is the config on my SGE2010 switch in Layer 3 mode :-interface port-channel 1description "PCI VLAN1"exitvlan databasevlan 2exitinterface range ethernet 1/g(13-18,37-42)switchport ...
Hello,I am interesting what Combo ports mean in ESW 540 which has 4 SFP? Can I use 4 optic SFP at the same time(or 1000BaseT SFP) ??
Hi,i just got one of the SG 300-52 Switches, and i wondering if there is any tool from cisco for montioring/configuring/etc that supports this type of switch.I tried with Cisco Network Manager but seems like the software is not discovering the switch...
Hi,I keep losing the web interface on our router.I telnet to ports 80/443 and get no response.Restarting the router will bring up the interface, but then the next day I can't gain access.Is there a lock out feature etc? Any other way I can access the...
