Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
I am looking to isolate ports 1-23 from seeing one another, yet I would like to share port 24 (uplink to Internet connection) with each port.(so that each computer could see the Internet, but could not see each other)I've found a million documents wh...
So I found a wireshark capture and I want to differentiate between the ISL and the Dot1q header.Here is the direct link of the capture: https://wiki.wireshark.org/uploads/__moin_import__/attachments/SampleCaptures/isl-2-dot1q.capYou can find it hereh...
I read that CDP, VTP, and PAgP updates are always forwarded on trunks with a VLAN 1 tag. https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/24330-185.htmlBut what I saw in the capture that these updates(I just checked c...
Hi All,  I'm doing some self-guided Wireshark training on Udemy in order to better understand and troubleshoot my network. One of the topics today was retransmission, which I see a lot of in my captures and something I haven't been able to understand...
dbronco by Level 1
  • 347 Views
  • 8 replies
we have several cisco switches. we have NTP setup running on a msfc of a 6500. switches are set to get time from 6500. the show clock command on the switches show the correct time. But when something is put in the log file of the switch,the time ...
broow by Level 1
  • 29665 Views
  • 9 replies
Dear community memebers,I need to test a scenario containing cisco nexus 9300 switches on a virtual lab. I tried to configure vpc on my switches both in eve and gns3. But I have a problem. I configured my switches, and the vpc is formed fine and is u...
elahe by Level 1
  • 3248 Views
  • 9 replies
Hi team, Sorry to bother you, I need to migrate Avaya switches Base Software version = v5.3.2.017 to Catalyst 9200 switches Ios Xe 17.12.6. Does anyone have any methods or equivalent commands? Thanks for your help.Ciro Gustavo Mele.
Hello FreindsAre there any things missed in the NTP server Below config? VMs has issue associating with this NTP ServerBelow NTP Config==============WS3750-X#sh run | sec ntpntp source Vlan64ntp master 5ntp server 172.16.100.254WS3750-X# 1 of the VM ...
