Ask the Expert: Catalyst 2960-X and 2960-XR Switches Overview, Configuration, and Troubleshooting
Monica Lluis
Level 9
Level 9
The Cisco Catalyst 2960-X models provide Layer 2 switching and have one fixed power supply with an external redundant power supply. They provide 24 or 48 Gigabit Ethernet wire rate ports, PoE/PoE+ support, and four 1G Small Form-Factor Pluggable (SFP) or two 10G SFP+ uplinks. With FlexStack-Plus technology, the Cisco Catalyst 2960-X switches can be stacked up to 8 members with up to 80 Gbps stacking capacity for high scalability. During this presentations, Roopa R. will talk about the architecture and stacking of the Cisco Catalyst 2960-X and 2960-XR Series Switches. She will also cover packet walk through, overview, configuration and troubleshooting of various features on these switches like QOS, Security, Netflow, PnP etc.
You can ask questions about the architecture and stacking of the Cisco Catalyst 2960-X and 2960-XR Series Switches. She will also cover packet walk through, overview, configuration and troubleshooting of various features on these switches like QOS, Security, Netflow, PnP etc.
To participate in this event, please use the Reply Button to ask your question.
Ask questions from Tuesday May 10 to Friday May 20, 2016
Featured Experts
Santhosh Chidri Nagaraj is a Technical Leader in Enterprise Access Switching group at Cisco. He is an expert on Forwarding – 802.1X, Security, Cisco Identity, AAA, Radius, Cisco TrustSec technologies and products. Santhosh holds a Bachelor’s Degree in Mechanical Engineering from Bapuji Institute of Engineering and Technology and an MBA Kuvempu University in India.  He has 17 years of experience in IT and has been working at Cisco for 5.5 years. Prior to Cisco he worked at Texas Instruments India Pvt Limited, Novell, HCL Technologies.
Prabha Ganesan is a Software Engineer in Enterprise Access Switching group at Cisco. She is an expert on Forwarding – Platform, Forwarding L3, L2, ASIC Validation as well as Catalyst Switches technologies and products. Prabha holds a Bachelor’s Degree in B.E Computer Science and Engineering from Anna University in India.  She has 10 years of experience in IT and has been working at Cisco for 6.5 years. Prior to Cisco she worked at Computer Sciences Corporation.
Find other  https://supportforums.cisco.com/expert-corner/events.
** Ratings Encourage Participation! **
Please be sure to rate the Answers to Questions
https://supportforums.cisco.com/expert-corner/events ">https://supportforums.cisco.com/expert-corner/events.
We look forward to your participation. This event is open to all, including partners. Please Share this event in your social channels. Have a technical question? Get answers here before opening a TAC case by visiting the Cisco Support Community.
I hope you and your love ones are safe and healthy
Monica Lluis
Community Manager Lead
51 Replies 51
There is no stack-power support on 2960X.
Roopa
Monica Lluis
Level 9
Level 9
Why is it advised by Cisco not to use the switch with the uplink as stack master?­
Monica Lluis
There is no such restriction , not to use it. It is just possibly because if there is a master fail over, connectivity to the rest of the network would be lost. If you have redundant links, this should be fine to use the master uplink too.
Roopa
Monica Lluis
Level 9
Level 9
What are the compatible USB that can be plugged on the 2960x usb slot (some of my usb key does not work in production)?­
Monica Lluis
Cisco Supported USB devices works in 2960x usb slot from 256 MB to 8GB
Monica Lluis
Level 9
Level 9
Is there any restriction concerning automatic IOS update on a stack?­
Monica Lluis
There is no restriction. We would need to use a tar image for Auto upgrade.
Roopa
Monica Lluis
Level 9
Level 9
When a master is lost, is the process of election the same?­
Monica Lluis
Process of election is same, when a master is lost, member switch with highest priority, if the priority is same, switch with lowest mac address is elected as master
rizwan_syed1
What is the best practice tool for real environment ....Packet tracer or GNS3.....?
is there any future availability for Cisco Packet tracer for real environment practice...
Billm
We are upgrading to 2960 XRs.
How many power supplies do we need for a 4 stack?
I think 2 on the top unit and 1 each on the other 3?
3 stack would be the same, 2 on the top unit and 1 each on the other 2?
Bill
There is no restriction of power supplies for a stack, Stack can operate with all switches having single power supply, but if you want for a redundancy purpose, you can have two power supplies.
Prabha
harleyacha
Hi Cisco Experts,
I have a problem, I am about to deploy 4 new Cisco 2960-X 24 Ports +POE but my 2 switch are encountering intermittent connection due to uplink / trunk ports facing core switch are experiencing auto-reset. I hope somebody can help me / enlighten me why is it only the 2 switches are experiencing auto-reset on trunk port(s) while the other 2 are okay, knowing that they all have the same configurations and using the same Lan connection to Core switch.
Best Regards,
Harley Acha
Not sure which image you are using on the 2960X. Can you please load 15.2(2)E8 and check if you see the issue? I think it is a known issue.
Roopa
bill.hurley
Can you tell me if the 2960-X can be configured for NAT
