LACP using 2x 10G ports not showing 20G?
steven.t27
I currently have etherchannel configured to 2x 10g ports.
Cat_6509#sh run int ten8/1
Building configuration...
Current configuration : 156 bytes
interface TenGigabitEthernet8/1
 switchport
 switchport mode trunk
 channel-group 42 mode desirable
end
Cat_6509#sh run int ten9/1
interface TenGigabitEthernet9/1
 switchport
end
Cat_6509#
Cat_6509#sh int t8/1
TenGigabitEthernet8/1 is up, line protocol is up (connected)
  Hardware is C6k 10000Mb 802.3, address is fc99.4736.a2f0 (bia fc99.4736.a2f0)
  Description: 10 Gig GEC to MADDC (Spanned VLANS)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 5/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s
Cat_6509#sh int t9/1
TenGigabitEthernet9/1 is up, line protocol is up (connected)
  Hardware is C6k 10000Mb 802.3, address is fc99.4736.a238 (bia fc99.4736.a238)
     reliability 255/255, txload 8/255, rxload 1/255
  Full-duplex, 10Gb/s
Cat_6509#sh int po42
Port-channel42 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is fc99.4736.a2f0 (bia fc99.4736.a2f0)
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 7/255, rxload 1/255
  Full-duplex, 10Gb/s               <<<<<<<<<<<<<<<<<<<<<<< Should this be 20GB if the ports are bundled?
Cat_6509#show etherchannel 42 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 28
Number of aggregators:           28
Group  Port-channel  Protocol    Ports
42     Po42(SU)        PAgP      Te8/1(P)       Te9/1(P)
Last applied Hash Distribution Algorithm: Fixed
Cat_6509#
ST
8 Replies 8
Zach Smith
(this will take down your port-channel)
Your description is 'LACP...' yet you are using PagP.  Issue below commands on both physical interfaces.  Does this change the speed of the port-channel?
'no channel-group 42 mode desirable'
'channel-group 42 mode active'
Hi WannaB
Oops you are right the configuration is in PagP. However I have another port channel from the 7706 to Fabric Interconnect which is configured as LACP that is still operating on 10G.
ethernet# show int po30
port-channel30 is up
admin state is up
  Hardware: Port-Channel, address: 8480.2da5.c36c (bia 8480.2da5.c36c)
  Description: UCS Fabric Interconnect A
  Encapsulation ARPA, medium is broadcast
  Port mode is trunk
  full-duplex, 10 Gb/s
ethernet# show port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SD)     Eth      NONE      --
2     Po2(SD)     Eth      NONE      --
3     Po3(SU)     Eth      LACP      Eth1/2(P)    Eth2/2(P)
30    Po30(SU)    Eth      LACP      Eth1/5(P)    Eth2/5(D)
ethernet# sh run int eth1/5
!Command: show running-config interface Ethernet1/5
!Time: Thu Dec 11 02:43:46 2014
version 6.2(8a)
  description UCS Fabric Interconnect A
  switchport
  channel-group 30 mode active
  no shutdown
ethernet# sh run int eth2/5
!Command: show running-config interface Ethernet2/5
!Time: Thu Dec 11 02:43:48 2014
version 6.2(8a)
  switchport
  no shutdown
ethernet#
Is the NIC teaming on the other end setup to use both NICs or for failover only?
Thanks WannaB
show int port-channel xx shows the total bandwidth :)
Our 7606 shows
Port-channel30 is up, line protocol is up (connected)
  Hardware is EtherChannel, .........
  MTU 9216 bytes, BW 20000000 Kbit/sec, DLY 10 usec,
  Full-duplex, 10Gb/s
  Transport mode LAN (10GBASE-R, 10.3125Gb/s)
  input flow-control is off, output flow-control is off
  Members in this channel: Te3/4 Te3/8
but ASR1004 had a bit different output
Port-channel10 is up, line protocol is up
  Hardware is 10GEChannel, address .......
  MTU 1600 bytes, BW 20000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 87/255, rxload 161/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (30 sec)
    No. of active members in this channel: 2
        Member 0 : TenGigabitEthernet1/0/0 , Full-duplex, 10000Mb/s
        Member 1 : TenGigabitEthernet1/1/0 , Full-duplex, 10000Mb/s
    No. of PF_JUMBO supported members in this channel : 2
but in both outputs BW 20000000 Kbit/sec. So this is a cosmetic bug in output.
Looks normal to me , you have a link in your port channel down.
tiwang
Level 3
Level 3
hi steven
I would say that it is correct - the bandwith is 20Gbps
