Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 15070 Views
  • 29 replies
  • 2 Helpful votes
I bought a Cisco Catalyst switch from a hamfest (amateur radio swap meet) and am trying to get it working.  I am a retired software engineer and am just looking to get this working.  I can connect to it through a serial conection and can run some ini...
Hi,I was configuring from scratch a C9500-24Y stackwise setup. It worked; we powered it off (not yet time for the production move).At one point we powered it on, to check something. I work remote so I have helping hands locally. For some reason i was...
meerakikat by • Community Member
  • 92 Views
  • 2 replies
Switches - MS software versions MS 18.1.8.1 changelogImportant alertsMS130-24(P) switches will reboot twice during the upgrade process when transitioning to MS 18.1.8 (or later) from MS 18.1.7 or earlier. This behaviour is expected, and is not indica...
CMR by • Meraki Community All-Star
  • 508 Views
  • 4 replies
  • 3 Helpful votes
Hi,I was not able to ssh into a switch, the consoled in and found out all vty sessions filled out with idle sessions thats why i was rejected to ssh. question is why switch did not end those sessions and exec-timeout did not work?! see details in the...
CISCO C9500 32C has no uplink ports, so is the case like it cannot be used in access or Distribution layer? Also, Is it necessary that   Uplink ports must be always SFP ports? ( Since we have to use fibre optic cable for uplinking)
Hey all,Can i configure two port of a same switch for redundancy of ISP which is 9300 L3 switchi am having two isp and also two L3 switch but both of them is need to be connected in stack and also i need to configure HA for Both these ISP is there an...
Hi,few month ago 17.15.5 turned to be the recommended IOS-XE version and now with these vulnaibility there should be an upgrade from it. what do you recommend and advise? 17.18.4, 17.15.6 or anything ?https://sec.cloudapps.cisco.com/security/center/c...
I don't want to steal anybodies time... Just found - after 15 years using those devices in depth, teaching several QoS-Classes - nobody noticed that, really?"60 - 64" - ... DSCP 64? So beautiful!https://www.cisco.com/c/en/us/td/docs/switches/lan/cata...
Important alertsMS130-24(P) switches will reboot twice during the upgrade process when transitioning to MS 18.1.8 (or later) from MS 18.1.7 or earlier. This behavior is expected, and is not indicative of a problem.New feature highlightsGroup Policy A...
Raphael_L by • Meraki Community All-Star
  • 1209 Views
  • 8 replies
  • 1 Helpful votes
