Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
I have a customer who is struggling with the Thumbscrews that are used to secure these cables to the routers.   I am trying to find out if there is a part number associated with them and if it is possible to purchase replacement screws.     Or if the...
sfein by Level 1
  • 180 Views
  • 1 replies
I am looking for AKIPS monitoring tool for cisco devices. Given the requirements below I am concerned as to the load AKIPS may place on network devices. Any idea on the load imposed by AKIPS ? Any Way to do impact assessment ? Any document ?   5000+...
rajulpar by Cisco Employee
  • 1714 Views
  • 5 replies
Hi all,I have in my hand an sg300-28p with firmware 1.3.0.62 and bootloader 1.1.0.6. I want to put it in the latest version (I'm aware of the in-between I have to do because of new bootloader version) but I don't see any firmware for my switch.There ...
elwan by Level 1
  • 3571 Views
  • 4 replies
Hi there,Thanks for reading!I'm seeing an oddity when trying to join a laptop to an SSID in PT.  The problem is in the UI where I set configuration for Wireless0 nic.  When I select an authentication type, the cursor jumps to the WEP password field a...
Hello,I'm looking for some direction on upgrading this platform, it is currently on IOS 12.2(35) SE5.Curious if this requires multiple upgrades and what version I should upgrade to? (I'm assuming 15.X) Thank you.
uadmin by Level 1
  • 423 Views
  • 10 replies
After Factory reset I install system from TFTP server.Now switch stuck in rommon after reebotPlatform C9300LPLATFORM_TYPE C9300L speed 9600Booting Recovery Image 16.12.1 Initiating Emergency Installation of bundle tftp:///cat9k_iosxe.17.18.01.SPA.bin...
I am planning to replace a Cisco 3750E-24TD with Cisco 2960G-24TC.I wanted to make sure that 2960 will handle the load. When I went through the datasheets, I got the below queries. What is the difference between Forwarding Bandwidth & Forwarding rate...
I have a 9200L-48P-4X switch stacked with a 9200L-48P-10G. When attempting to update to version 17.09.05, I encounter a "low disk" error on the 1G switch, while the 10G switch does not have this issue. The update image copies to the switch, but when ...
ezejazz by Level 1
  • 1539 Views
  • 11 replies
