05-13-2016 03:45 AM - edited 03-18-2019 05:56 AM
Hi TelePresence Experts,
When I connect my laptop with sx20 and click on 'call control tab' a message shows in the two displays of the laptop. The message is "Snapshots require the RemoteMonitoring option key". Would you clarify me the reason and the function of 'call control tab' please....
Thanks in advance.
Nizam
Solved! Go to Solution.
05-13-2016 06:06 AM
Suggest you take a look at the admin guide - page 10 onwards tells you all about the web interface.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
05-13-2016 01:29 PM
You can obtain the Remote Monitoring option key from Cisco Licensing and install it by navigating to Maintenance > Option Keys on you SX20.
05-13-2016 03:44 PM
The Remote Monitoring Option Key is no longer free, so you need to contact your partner or Cisco account manager to purchase it.
/jens
05-15-2016 02:38 PM
As I pointed out in my previous reply, the Remote Monitoring Key is no longer free and has to be purchased, so you need to go through your Cisco partner or Cisco Account Manager to obtain this.
This changed in January 2016, prior to that you could get the key for free from Cisco TAC, but that is no longer the case.
The part number to need to order is L-SX-SERIES-RM, last time I checked the cost was approx US$100,-.
/jens
05-15-2016 07:00 PM
The Remote Monitoring Key is only required if you wish to view the snapshots of the camera and content via the web interface.
The other functionality on the page (such as the ability to Dial, Hang-up, view the Directory and recent call list) works without the RM key.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
05-13-2016 06:06 AM
/jens
05-13-2016 12:08 PM
Hi Jens,
Thanks for your reply and sharing the documents. I've found that remote monitoring option key needs to install. Would you help me how to install this ?
I'm waiting for your reply.
Nizam
05-13-2016 01:29 PM
05-15-2016 05:23 AM
Hi Shasmaha,
Thank you very much for your pin point ans.
Actually I'm new in this area. So would you please tell me the procedure/steps of collection the remote monitoring option key from cisco.
Nizam
05-15-2016 02:38 PM
/jens
05-15-2016 06:57 PM
The top level SKU for this is L-TP-RM.
Then use L-C-SERIES-RM, L-MX-SERIES-RM, L-SX-SERIES-RM, L-EX-SERIES-RM or L-PROF-SERIES-RM underneath that depending on the endpoint you need the Remote Monitoring licence for.
Wayne
05-13-2016 03:44 PM
/jens
05-15-2016 07:00 PM
Wayne
