Polycom sip phone cme
akinsconsulting
has anyone been able to register a polycom sip phone on a callmanager express? i especially need help on configuring the polycom phone
5 Replies 5
Dennis Fogler
I have not been able to get the 3rd Party Polycom SIP phone to register with Call Manager Express either. The feedback I am getting is that 3rd Party SIP Phones are curently not being supported on Call Manager Express.
Rob Huffman
Hi Shawn/Dennis,
Have a look at this good note from Tony Huyhn, a technical marketing engineer for Cisco CallManager Express (CME) at Cisco Systems. This answer is from a current "Ask the Expert" event on CME.
Yes, you can register (Cisco only) sip phones to CME as of CME 3.4, IOS 12.4(4)T
Here is the thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddd265e
Hope this helps!
Rob
thanks for the link, Rob.
I actually was able to get one of the Line buttons to register on CME as an extension. i can make calls to other extensions and call this extension but am unable to call out the PSTN.
the phone doesn't register though, but the line button does. not very familiar with Polycom phones which is my issue.
derek.small
Level 5
Level 5
I just got this to work with a SoundPoint 501. Took some fiddling, but phone is registered and seems to work Ok. Still working on some issues with WMI and getting the messages button to work correctly, but the phone is registered.
here is the config:
voice register global
mode cme
source-address 10.72.13.19 port 5060
max-dn 200
max-pool 20
timezone 13
tftp-path slot0:
create profile sync 0390651099874124
ntp-server 10.71.13.19 mode directedbroadcast
voice register dn 1
number 4020
allow watch
voice register template 1
session-transport udp
softkeys hold Resume Newcall
softkeys idle Newcall Redial Cfwdall
softkeys connected Endcall Trnsfer Confrn Hold
voicemail 4200 timeout 30
voice register dialplan 1
type 7940-7960-others
pattern 1 4...
pattern 2 ....
pattern 3 .
voice register pool 1
id mac 0004.F213.2465
type P600
number 1 dn 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
Hi derek
I saw you reply , do i need to do anything other than above configuration
do i need any files on the TFTP server for polycom, i am trying to configure polycom 560
Sri
