CUC 8.6 instllation issue
bkhanal1971
Level 3
Level 3
I am trying to install Unity connection 8.6 in my lab environment but i dont' see the Unity connection as an install option. I tried to install many times but everytime the install option defaults to CUCM only. Any idea why so. I am using a low end Dell PE T110II with a few VMs.
Thank you for the help.
Bradley Gruesbeck
If you don't see unity connection as an install option that means that the media isn't detecting adequate hardware. Are you using an ova template?
I would recommend looking up the hardware guide and make sure you have adequate gear to run it.
Good luck.
Some media doesn't come with CUC, that will depend in the version you're installing.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Simon Leigh
Make sure that your hard drive has at least 200 gb of free space on it.
You 'should' then see the option for unity.
Thank you everyone who responded. As you all indicated, I was low on hardware resources. After I tried with 4 GB of RAM and 160+ GB harddrive, I got Unity Connection as an install option. Thank you all.
