IP Communicator and Extension Mobility not working
DOUG DAVIDSON
Level 5
Level 5
I have a couple of users running IP Communicator 8.6 that are setup with Extension Mobility and it is not working. When you select the service, it displays,  "Extension Mobility" at the top of the screen but you never see the fields to provide login information.
It was working fine with older version of IP Communicator.
Thanks in advance,
Doug
10 Replies 10
anchoudh
Level 9
Level 9
Hi Doug,
Cold you please try unsubscribe and subscribe the "EM" feature on these IPC's one more time and see if it helps.
Anand
Please rate helpful posts !!
ronpatel
Level 8
Level 8
Hi Doug,
Are you using HTTP or HTTPS for EM service.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I will double check but I think it is http.
Doug
Please check as CIPC do not support HTTPS. It only suports HTTP.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtx18810
Ronak patel
Please rate if it is helpful .
Also let me know the CUCM version and what URL you are using in the EM service configuration page.
Ronak Patel
Please rate all helpful posts.
dcaufman1
Same issue here w/ IPC 8.6.1 and CUCM 8.6.2
Below is how we are finally able to get it working
In CUCM edit the IPC device
Under "External Data Locations Information" enter the HTTP string for the EM service -  (http://:8080/emapp/EMAppServlet?device=#DEVICENAME#&EMCC=#EMCC#) - into the following fields:
     Services
     Authentication Server
     Proxy Server
Unsubscribe from EM
Subscribe to EM
Good Luck
To solve this problem you need to:
Go to Ip Phone Services Configuration and choose the extension mobility service.
After that you have to change the Secure-Service URL parameter. The original is
https://:8443/emapp/EMAppServlet?device=#DEVICENAME#&EMCC=#EMCC#
You have to change the https to http and 8443 to 8080 like the example below:
Dante
This is not working for me. Can someone provide more detailed instructions?
I see the EM service on IPC but can't select it.
-Kleid
malnasle
CSCud94019            Bug Details
CUCM Unified Reporting tool incorrectly mentions that CIPC supports EMCC
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud94019
Better late than never, but I found out the problem. I removed the &EMCC=#EMCC# from the URL and low and behold it works for both IP Phone and IPC.
It may take a while sometimes, but I will find the issue.
Hope this will help someone else,
Doug
