Problem fInd phone with specific description in CUCM 15
herucisco
Good day everyone,
I have issue after upgrade CUCM from 12.5 to 15.0, where I cannot find phone especially with specific detail.
In my case, I tried to find phone with specific description and filter "contains". when I click find button only showed total records found, the list phone is not displayed
but if I change filter to be "begin" it works as expected
anyone experience same after upgrade to 15.0?, or is this bug ?
Please your help.
Thank you.
You are hit with this BUG CSCwj21390. apply the work around mentioned in the BUG ID and it will be fixed.
Response Signature
13 Replies 13
I have not seen this on any of the systems we have updated to v15, neither on the FCS or any of the SU releases.
Response Signature
Have you tried using a different browser? This issue might be browser-related. If the behavior is the same across different browsers, I recommend reaching out to TAC.
Response Signature
Yes I have tried using 3 different browser (chrome, edge and firefox) but the result is same
Is this issue occurring only with this specific name?
How is your database? Does it look good, or are there any errors?
TAC should be able to provide an explanation for this behavior.
Response Signature
- May need to Clear your browser cache or try using a different browser.
- Ensure that the user account you're logged in with has sufficient permissions to view phone records. Sometimes after upgrades, user roles or permissions might need adjustments.
-  Try restarting the CUCM Publisher and Subscriber servers to refresh the services and re-sync data
- If the issue persists, a TAC case might be needed for further investigation.
As suggested, check for database consistency. If it checks out, I agree with @Nithin Eluvathingal that you will want to open a TAC case.
Troubleshoot CUCM Database Replication Issues
Maren
What model phone is it? Is it a model that was deprecated in V15? Was the read only lock out overridden while the upgrade was running and something was alter regarding this phone that caused the inconsistency? I will echo the sentiments of @Roger Kallberg , @Nithin Eluvathingal , and @Maren Mahoney in that I have never seen this and I have done a number of upgrades to V15.
Response Signature
Thank you Nithin, the issue was resolved after apply workaround
Thank you, I had this bug with my customer also, after the workaround it worked fine.
herucisco
Thanks all, for your advice and fast response
It's possible to perform a correct search using two filters.
It's a way to trick the BUG.
keyur.prajapati
We had similar issue in finding all phones with filter "Device Type" when number of rows changed from default 50 to 250. Followed below steps to resolve it:
  1. just search all phones with 50 rows with "device name" filter
  2. then change filter to device type
  3. add particular model number in search field.
