Viewmail 9.0 Enterprise Deployment - Almost Silent - One Prompt Left
Tony Musorafite
Hello -
Is it possible to deploy Cisco viewmail so that it does not ask users to confirm their phone number when they first start outlook up? I have all the fields pre-populated including that one, like server name and type which the user does not get prompted for.
But when they open outlook for the first time, the Phone Number field is populated correctly with their extension but they still have to hit next to confirm, and next once again to complete the initialize cisco viewmail screen. Which is kind of unnecessary since the field is already filled in properly.
Is it possible to bypass the phone number step? Assuming the field is pre-populated correctly.
Thank you,
Tony
Sorry guys I haven't been checking this forum. Attached is my script. you have to remane the to .vbs you need to change two entries:
1- Unity connection FQDN line 74  and 75 to your Unity connection server.
2- Active directory domain, line 111
Good luck
11 Replies 11
Tony,
Did you ever find a solution to this?   We are trying to do the same thing.
Glenn
Glenn,
Unforunately, I was not able to find a solution. In the end we opted NOT to deploy viewmail at all since it can't be done without any intialize prompts. It would've generated too many calls.
We listen to voice messages with quicktime or iTunes and we don't forward voice messages.
Good luck and let us know if you find a solution.
Tony
Hi Tony,
There is a way to silence the configuration wizard, you can do that with a logon script that runs after VMO is installed.
Every time VMO starts it checks HasRun registry value under : HKEY_CURRENT_USER\Software\Cisco Systems\ViewMail for Outlook\Profiles\Outlook\Wizard  to see if it needs to run the config wizard or not. value of 1 means it don't start the wizard. I created a logon script that sets the value to 1, when the users opens his outlook VMO checks the value and will not start the Wizard. You can even fully automate VMO profile creation and configure how voicemessages wil be played via phone or PC.
Let me know if you need more help. I'll be happy to share my script with you.
Aomar.
Will you be able to share your script please? I am looking to create the profile and set the playback to be phone.
Please rate useful posts.
Hi Aomar,
I am also trying to deploy VMO at the moment, but getting stuck with the script. Can you help?
Oliver
Good luck
Hi Aomar,
Thanks for the script, Ill do some testing.
Cheers
Oliver
Hi Oliver,
How did it go with the script?
Aomar.
Hi Aomar,
Thanks for the follow-up.
The script worked perfectly. I had to change sEmail=oUser.mail to mailNickName as out exchange is set up a little different.
Many Thanks
Oliver
I'm glad to hear that.
Aomar.
Hi Aomar,
Oliver
