Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I getting the follow erro message when I session into the CUE of the UC520. All advice appreciated. I read the similar post, however  I'm not given any prompts to make a selection. --------------------Buffer I/O error on device hda1, logical block 81...
HiI have a SP525G2, undertion options > 7 > 5 (Call Record Configuration) both options have check marks.I have a USB drive inserted (FAT32), options > 10 > 5 > says USB connectedOutside calls are not recorded and niether are internal ones, how do i d...
Ever since my phone (SPA303) upgraded to software version 7.5.5 I have had an issue with the key pad bleeding over the mic while on speaker.Example.When I am on speaker and dial into a conference line that requires a pin, when I dial in pin (example)...
I have an interesting problem which I'm sure can be done just not sure.  I have a client which has an ATA.  When she leaves her office she forwards the calls to her cell phone and at present the number showing up on her phone when the forwarding is i...
swensonj by Level 1
  • 555 Views
  • 4 replies
I have the basic XML Directory stuff working (CiscoIPPhoneDirectory) on the SPA504G. However I realise I can only display 32 entries and I note that there is a "next" softkey enabled, however it seems to not do anything. How can I link this button pr...
I am not sure if this is a SIP provider thing or a phone config. I have a SIP account registered on a SPA5252G2. On an inbound call I answer and can put the caller on hold by pressing the 'Transfer' softkey. I get a new dial tone and I enter the exte...
Hi - there are two files that come down in the SPA525G2 F/W update for 7.5.7:spa525g-7-5-7.binspa525g-7-5-7-bt.binI can't find any info as to which one I should be using. I assume all the SPA525G2's have the bluetooth module (I can see BT details in ...
