I have to configure uc520 to filter out a few ports between the two vlans I have and I don't know how. Is it possible to do it with CCA or is it better to do it through ssh? I don't even know what are my options.
I am using spa3102 in uae but it always giving me busy tone. Anybody have the right configuration for ETISALAT..? or anybody using in uae successfully pls share the configuration ..thanx
Hi all, I am having a problem with the SPA2102 where DTMF tones are spuriously generated during voice calls, and a lot of echo as well. Any tips? ThanksSteve.
I'm having to reinstall Unified CallConnector Server & Mobility on our Windows 2003 Server. When I installed it several months ago, I had no problems but now I keep getting the following error."Error 1401: Could not create key HKEY_LOCAL_MACHINE\Sof...
ephone-dn 28number 622paging ip 239.1.1.2 port 2000paging group 2ephone 6mac-address 0000.0000.0000paging-dn 28type 7921button 1:10 2:11 3:12 4:13 6:2When calling 622 from a 7965 I cannot recieve any pages on the 7921 phones. Any thoughts?P.S. I ins...
I have an SPA921 IP phone at a remote site that is pointing to an SPA3102 gateway that has an old analog phone attached to it. We can successfully dial each other and hear just fine. The problem that I am currently having is that when I want to dia...
Hi All,I am config the connection between SPA400 to SPA9000. My problme is when I make called between outside mobile phone to internal phone. I can hear outside phone but the outside phone can not hear sound from the inside phone.Do you know any conf...
Hi,I was a happy user of a PAP2T-NA with the latest FW version. Everything has been working perfectly until today when tried to change some configuration. I did quite a number of changes all of which worked fine.At some point after hitting Save the u...
Hey guys,I was tryng to determie if anybody has had an success connecting up their cellphone-style bluetooth headset with their CIPC softphone? I can get the headset to pair with the computer, but the CIPC doesn't seem to recognize it. Any ideas? I...
I have e-mail notification of voicemails setup on my UC520 and have everything set so that the vm message gets attached to the e-mail as a .wav file. However, the volume is very low, such that I can only make out what is said if I crank the volume a...
Hi All,System UC520I can call the the analogue extension the cordless phone is on but i can NOT Transfer to it. Is there anything i should enable to allow transfer to analogue port?below is the running config for that port.voice-port 0/0/2 cptone AU ...
Hello,I have just bought a SPA9000 with 4 962 phones. I cannot find the french files for the voice mail. On USB stick only english files are available and on cisco support, files are not available without specific account access.Where can I get those...
We have a site with 6 FXO lines. They want extensions 201 and 202 to make outgoing calls on 0/1/0, 0/1/1, or 0/1/2. All other calls should go out 0/1/3, 0/2/0, and 0/2/1.What is the easiest way to accomplish this?
How do I obtain an evaluation license for the UC520? I was looking over the documentation, and I noticed that I could install an evaluation license on the UC520. Will the evaluation license increase the capacity of an UC520-8U-4FXO-K9 from 8 users to...
Hi All,I have just installed the VWIC-1MFT-E1-RF on my UC.I don't see any action on the card leds when connecting the PRI from the provider, nor does the controller/interface serial showing on CLI.It looks like the card hardware is not detected by th...
