We have a customer with a 524G phone. The MWI comes on at random times. Sometimes it stays lit for days. There are no voicemails for this user or extension. I replaced the phone with another 524G and the problem still happens. I deleted the user...
Does anyone have a idea on setting up IPv6 on the UC500.I found thishttp://forums.whirlpool.net.au/forum-replies-archive.cfm/1049820.htmlDoes this apply to a UC500? How about the Phones?ThanxAndy Gribnau
Hi All,We have a SPA9000 with a SPA400 and a SPA962 and three SPA922's. We are using an ITSP on line two and are trying to configure the auto attendant to pick up after twenty seconds. The inbound call rings and after twenty seconds the call is cut o...
I can't do this? Is this a bug or a known limitation? This is my first deployment and this company has a lot of users are almost trained to dial a certain extension when dialing in.
Hey guys,OK we deployed two 7921 phones at our client, the client has the mobility controller and 2 lightweight AP's that are fully configured. Wireless works fine, the phones can get an IP but can't get their load information.I compared the phone bo...
Hi guys,I'm having difficult times figuring out this issue, we have a branch down in Chile, they have an ASA5505 and behind it there is an UC520, the UC520 ATT is in English but they want to change the ATT to Spanish obviously most of their costumers...
HelloWe have a SPA9000 setup as described here.All is working fine with exception of the call pickup and call park features.If we try to pick up a call ringing on another phone, the caller hears us but we don't hear anything from the caller. We found...
Hi,Can anybody shed any light on to when the SPA phones will lose their "Linksys" branding and become Cisco?We had a delivery of 20 SPA942 from UK Distribution the other day and they were still branded Linksys. The distributor had only just received...
Is there a way to allow users to manually switch the auto attendant from an open version to a closed version? Night Service doesn't seem like it would be what i want but maybe it is and i just don't understand how it works...Thanks Much!
Hi,When my IP Phone received a missed call, i would select the missed number and dial straight. But unable to do so, as the dialing is missing a access code, example when making a call, the caller need to press access code follow by number. Example;9...
I create longest idle time hunt group.Every thing is working properly but the problem is.We did not receive any calls on thid extention as per logest idle time. Only if the both two of extentions are busy then we receive on third extention.Please gui...
Hello team,I´m wondering, is it possible to get the "user" tab under an own link in telephony-service, instead of putting it under the "voice" link. This is due to alot of our deployments where businesses don´t need or want to create individual users...
Hi all,We recently deployed CallConnector Server and mobility on our server and deployed all the clients. However, the call logs appear blank for all the users. I opened up the callog.mdb file using Access and sure enough the table is completly empty...
If i have public ip address on the UC500 can i use CCA to access to box?Thanks...
Hi,How can i block calls using UC? Block 24x7. Example, need to block the following sample cellphones.010220771401825046780182612150Please provide configuration assistant.Best regards,Lawrence Chew
