new uc560 8.6 with only 16 licenses? how i get to 24?
Jeff Cooper
I just opened my new uc560 to prep for installation.  I checked the license count and it says 16.  It is already running 8.6.  How do i get my additional 8 licenses?
System image file is "flash:uc500-advipservicesk9-mz.151-4.M4b"
UC560#show license detail
Index: 1        Feature: uc-user                           Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        Lock type: Node locked
        Vendor info: <PID>UC560-T1E1-K9</PID><SN>FGL163911U1</SN>
        License Addition: Exclusive
        License Generation version: 0x8100000
        License Count: 16/16/0  (Active/In-use/Violation)
        License Priority: Medium
        Store Index: 0
        Store Name: Primary License Storage
Index: 2        Feature: uc-user                           Version: 1.0
        License Type: Evaluation
        License State: Inactive
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        Lock type: Non Node locked
        Vendor info:
        License Addition: Additive
        License Count: 104/0/0  (Active/In-use/Violation)
        License Priority: None
        Store Index: 0
        Store Name: Built-In License Storage
Hello Jeff,
The command to check the licenses is "show platform software license "
HTH,
Alex
*Please rate helpful posts
paolo bevilacqua
I checked another 560, 'show license' is the same as your,  but in 'show ver' can see:
Cisco UC560-T1E1-K9 (MPC8378) processor (revision 0x100) with 497664K/26624K bytes of memory.
Processor board ID FGL162110LJ
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
30 User Licenses
4 Gigabit Ethernet interfaces
... etc
So try connecting all the phones and if still trouble contact licensing@cisco.com
Paolo,
i'll plug it back in and check that here..  thx!
Hello Jeff,
HTH,
Alex
