10-26-2012 06:09 AM - edited 03-21-2019 09:54 AM
Hi, I am a home user and ex-programmer. I'm using the Cisco SPA112 with the latest firmware 1.2.1 (004). Every two or three days the ATA crashes. Here are the symptoms:
a) no dial tone
b) line 1 LED is ON (as normal)
c) ATA is PINGable
d) IVR is unresponsive
e) web setup URL does not respond, can not get to the setup page
f) The reset button does not respond.
My only recourse now is the check if I have a dialtone every morning and, if not, pull and reinsert the power plug. The cold boot of course results in the local log being lost. Here is the log right after boot up.
Jan 1 00:00:04 SPA112 kern.warning [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Jan 1 00:00:04 SPA112 kern.warning [ 0.000000] Machine: NXP PNX8181
Jan 1 00:00:04 SPA112 kern.warning [ 0.000000] Memory policy: ECC disabled, Data cache writeback
Jan 1 00:00:04 SPA112 kern.warning [ 0.000000] CPU0: D VIVT write-back cache
Jan 1 00:00:04 SPA112 kern.warning [ 0.000000] CPU0: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Jan 1 00:00:04 SPA112 kern.warning [ 0.000000] CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Jan 1 00:00:04 SPA112 kern.warning [17179569.184000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 7874
Jan 1 00:00:04 SPA112 kern.warning [17179569.184000] PID hash table entries: 128 (order: 7, 512 bytes)
Jan 1 00:00:04 SPA112 kern.warning [17179569.184000] Console: colour dummy device 80x30
Jan 1 00:00:04 SPA112 kern.warning [17179569.260000] Mount-cache hash table entries: 512
Jan 1 00:00:04 SPA112 kern.warning [17179569.264000] Board HW MODEL : 0x3
Jan 1 00:00:04 SPA112 kern.warning [17179569.336000] squashfs: LZMA suppport for slax.org by jro
Jan 1 00:00:04 SPA112 kern.warning [17179569.384000] [ip3912] : Bridge Mode...
Jan 1 00:00:04 SPA112 kern.err [17179569.408000] physmap-flash physmap-flash.0: map_probe failed
Jan 1 00:00:04 SPA112 kern.warning [17179569.416000] Using Full Image\'s RootFS
Jan 1 00:00:04 SPA112 kern.warning [17179569.420000] Using static partition definition
Jan 1 00:00:04 SPA112 kern.warning [17179569.424000] !!! do adler32 checksum !!!
Jan 1 00:00:04 SPA112 kern.warning [17179571.260000] File system image checksum OK
Jan 1 00:00:04 SPA112 kern.err [17179571.344000] ksz8873 0-005f: failed with status -1
Jan 1 00:00:04 SPA112 kern.warning [17179571.348000] ksz8873: probe of 0-005f failed with error -1
Jan 1 00:00:04 SPA112 kern.warning [17179571.352000] PNX8181 watchdog timer: timer margin 16 sec
Jan 1 00:00:04 SPA112 kern.warning [17179571.372000] GACT probability on
Jan 1 00:00:04 SPA112 kern.warning [17179571.376000] Mirror/redirect action on
Jan 1 00:00:04 SPA112 kern.warning [17179571.380000] u32 classifier
Jan 1 00:00:04 SPA112 kern.warning [17179571.384000] Performance counters on
Jan 1 00:00:04 SPA112 kern.warning [17179571.388000] input device check on
Jan 1 00:00:04 SPA112 kern.warning [17179571.392000] Actions configured
Jan 1 00:00:04 SPA112 kern.warning [17179571.396000] Netfilter messages via NETLINK v0.30.
Jan 1 00:00:04 SPA112 kern.warning [17179571.400000] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
Jan 1 00:00:04 SPA112 kern.warning [17179571.412000] ipt_time loading
Jan 1 00:00:04 SPA112 kern.warning [17179571.464000] VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:04 SPA112 kern.warning [17179576.144000] ***** LED_DRV init *****
Jan 1 00:00:04 SPA112 kern.warning [17179576.148000] ***** LED_DRV end *****
Jan 1 00:00:04 SPA112 kern.warning [17179576.176000] *** sys event driver initialized ***
Jan 1 00:00:04 SPA112 kern.err [17179579.184000] br0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
Jan 1 00:00:04 SPA112 kern.warning [17179580.880000] Empty flash at 0x00069454 ends at 0x00069600
Jan 1 00:00:05 SPA112 daemon.err dnsmasq[136]: failed to load names from /etc/hosts: No such file or directory
Jan 1 00:00:23 SPA112 kern.err [17179600.844000] br0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
Jan 1 00:00:27 SPA112 daemon.err system[1]: notify add wan1 interface(br0)
Jan 1 00:00:27 SPA112 daemon.err system[1]: start 0 vlan-id... ok
Jan 1 00:00:39 SPA112 daemon.err dnsmasq[136]: failed to load names from /etc/hosts: No such file or directory
Here are some things I have tried on my own, to no effect:
a) Tried running with Provisioning/Firmware Upgrade/Upgrade set to false.
b) Reloaded the firmware with IE. Before, I did it with FireFox.
c) Did a factory reset and re-entered the settings suggested for my ATA from Callcentric.
How should I proceed?
