Trying Register 3rd Party SIP phone with UC540
networkwise
I have a UC540. Im trying to register an iSoftphone Pro Mac softphone client with the UC540. The particular UC540 already has a number of Cisco 7900 series phones registered using the default cisco protocol SCCP and is working with no problems. There are some Mac users that would like to use a softphone with the UC540 hence this effort.
My configs and debugs are below.  The error messge I reieve is :
uc540#SIP/2.0 404 Not Found
Any advise would be appreciated.
Andy
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 4
max-pool 4
authenticate register
create profile sync 0428016071226793
voice register dn  1
number 500
name Andy's Phone
label 500
voice register pool  1
id mac 7CC3.A1A1.EF11
number 1 dn 1
dtmf-relay rtp-nte
username siptest password siptestpw
no vad
uc540#debug ccsip messages
016329: Jul  4 16:51:58.738: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.1.1.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1648049559
To: Andy <sip:siptest@10.1.1.1>
Call-ID: 280655791
CSeq: 1 REGISTER
Contact: <sip:siptest@192.168.10.12:5060;line=387f4495119c32d>
Allow: INVITE, ACK, CANCEL,  BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Max-Forwards: 70
User-Agent: iSoftPhone Pro 3.4112
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
016330: Jul  4 16:51:58.746: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 04 Jul 2012 16:51:58 GMT
Call-ID: 280655791
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 REGISTER
Content-Length: 0
016331: Jul  4 16:51:58.750: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: Andy <sip:siptest@10.1.1.1>;tag=31B9D8BC-20C3
Call-ID: 280655791
CSeq: 1 REGISTER
Content-Length: 0
uc540#debug voice register events
voice-register events debugging is on
016338: Jul  4 16:54:03.782: VOICE_REG_POOL: Register request for (siptest) from (192.168.10.12)
uc540#
uc540#show voice register pool 1
Pool Tag 1
Config:
  Mac address is 7CC3.A1A1.EF11
  Number list 1 : DN 1
  Proxy Ip address is 0.0.0.0
  DTMF Relay is enabled, rtp-nte
  Call Waiting is enabled
  DnD is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is not supported
  Privacy feature is not configured.
  Privacy button is disabled
Dialpeers created:
Statistics:
  Active registrations  : 0
  Total SIP phones registered: 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
uc540#
2 Accepted Solutions
Ok, now the problem is in authentication phase.
Can you try to add the authorization name in the sip client config? Can yiu set this parameters like username?
Regards.
Andy,
For your media unacceptable message, please try the following:
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g711alaw
 voice-class codec 1
Best,
David
Please rate helpful posts.
13 Replies 13
You have created a "voice register dn  1" for the  "number 500" but your REGISTER comes from
In the from header you must have the number 500. Try to set options of your iSoftPhone differently.
Regards.
Thanks Daniele,
I did what you said. And now I see the request coming from the appropiate extension number. There appears to be a lot more output now in the debugs. I alchanged the server address to the loopback address of the UC540 and the uername now reflects the extesion Im attempting to assign. I have also attached the output from the debug sccip.
Thanks for your help Daniele, the server and the client seem to be attempting to connect now. Still recieving the error.
Andy
uc540#
019099: Jul  4 19:11:03.652: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
jaK
uc540#
019100: Jul  4 19:11:11.768: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.1.10.2 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK36160373
To: Andy <240>
Call-ID: 1208271429
CSeq: 1 REGISTER
Contact: <240>
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019101: Jul  4 19:11:11.772: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: Andy <240>
Date: Wed, 04 Jul 2012 19:11:11 GMT
Call-ID: 1208271429
CSeq: 1 REGISTER
Content-Length: 0
019102: Jul  4 19:11:11.776: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
uc540#SIP/2.0 401 Unauthorized
To: Andy <240>;tag=32394CBC-A66
Call-ID: 1208271429
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="",nonce="9AAD70590505BADF",algorithm=MD5,qop="auth"
Content-Length: 0
019103: Jul  4 19:11:11.868: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1175814889
To: Andy <240>
Call-ID: 1208271429
CSeq: 2 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="9AAD70590505BADF", uri="sip:10.1.10.2", response="39abed637da9421c7e4bc6a465a9be76", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019104: Jul  4 19:11:11.880: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1208271429
CSeq: 2 REGISTER
Content-Length: 0
019105: Jul  4 19:11:11.880: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1208271429
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="",nonce="33FE9E460505BAE9",algorithm=MD5,qop="auth"
Content-Length: 0
019106: Jul  4 19:11:11.884: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK2038054015
To: Andy <240>
Call-ID: 1208271429
CSeq: 3 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="33FE9E460505BAE9", uri="sip:10.1.10.2", response="31034eca06c62ea538447880e30b0b2a", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019107: Jul  4 19:11:11.888: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1208271429
CSeq: 3 REGISTER
Content-Length: 0
019108: Jul  4 19:11:11.888: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1208271429
CSeq: 3 REGISTER
WWW-Authenticate: Digest realm="",nonce="F56ABB790505BAEB",algorithm=MD5,qop="auth"
Content-Length: 0
019109: Jul  4 19:11:11.908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK278642239
To: Andy <240>
Call-ID: 1208271429
CSeq: 4 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="F56ABB790505BAEB", uri="sip:10.1.10.2", response="06d570d3ac5ba187f8751b5df3e8ca85", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019110: Jul  4 19:11:11.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1208271429
CSeq: 4 REGISTER
Content-Length: 0
019111: Jul  4 19:11:11.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1208271429
CSeq: 4 REGISTER
WWW-Authenticate: Digest realm="",nonce="5AB097970505BAED",algorithm=MD5,qop="auth"
Content-Length: 0
019112: Jul  4 19:11:12.628: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1643870929
To: Andy <240>
Call-ID: 1734042639
CSeq: 1 REGISTER
Contact: <240>
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019113: Jul  4 19:11:12.632: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: Andy <240>
Date: Wed, 04 Jul 2012 19:11:12 GMT
Call-ID: 1734042639
CSeq: 1 REGISTER
Content-Length: 0
019114: Jul  4 19:11:12.632: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: Andy <240>;tag=32395014-2285
Call-ID: 1734042639
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="",nonce="A9F3FEDA0505BB35",algorithm=MD5,qop="auth"
Content-Length: 0
019115: Jul  4 19:11:12.648: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1919359816
To: Andy <240>
Call-ID: 1734042639
CSeq: 2 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="A9F3FEDA0505BB35", uri="sip:10.1.10.2", response="caeccd5564223e32cd628865234339cb", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019116: Jul  4 19:11:12.652: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1734042639
CSeq: 2 REGISTER
Content-Length: 0
019117: Jul  4 19:11:12.652: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1734042639
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="",nonce="2E9EC9240505BB37",algorithm=MD5,qop="auth"
Content-Length: 0
019118: Jul  4 19:11:12.756: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK475068034
To: Andy <240>
Call-ID: 1734042639
CSeq: 3 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="2E9EC9240505BB37", uri="sip:10.1.10.2", response="2a8eeb519e7d51db6786af2907dd8354", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019119: Jul  4 19:11:12.760: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1734042639
CSeq: 3 REGISTER
Content-Length: 0
019120: Jul  4 19:11:12.760: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1734042639
CSeq: 3 REGISTER
WWW-Authenticate: Digest realm="",nonce="743D5F560505BB42",algorithm=MD5,qop="auth"
Content-Length: 0
019121: Jul  4 19:11:12.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1803220260
To: Andy <240>
Call-ID: 1734042639
CSeq: 4 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="743D5F560505BB42", uri="sip:10.1.10.2", response="af2d7cab4923834b183d9e063bc145f0", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported:
uc540#100rel
Supported: path
Content-Length: 0
019122: Jul  4 19:11:12.772: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1734042639
CSeq: 4 REGISTER
Content-Length: 0
019123: Jul  4 19:11:12.772: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1734042639
CSeq: 4 REGISTER
WWW-Authenticate: Digest realm="",nonce="78E8E3170505BB43",algorithm=MD5,qop="auth"
Content-Length: 0
019124: Jul  4 19:11:13.392: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK221626188
To: Andy <240>
Call-ID: 1572679096
CSeq: 1 REGISTER
Contact: <240>
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019125: Jul  4 19:11:13.396: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: Andy <240>
Date: Wed, 04 Jul 2012 19:11:13 GMT
Call-ID: 1572679096
CSeq: 1 REGISTER
Content-Length: 0
019126: Jul  4 19:11:13.400: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: Andy <240>;tag=32395314-2538
Call-ID: 1572679096
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="",nonce="99D252EE0505BB82",algorithm=MD5,qop="auth"
Content-Length: 0
019127: Jul  4 19:11:13.404: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK126942806
To: Andy <240>
Call-ID: 1572679096
CSeq: 2 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="99D252EE0505BB82", uri="sip:10.1.10.2", response="6bde6112bf0f51a0ccbb086f19b82177", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019128: Jul  4 19:11:13.408: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1572679096
CSeq: 2 REGISTER
Content-Length: 0
019129: Jul  4 19:11:13.408: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1572679096
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="",nonce="F1A491ED0505BB83",algorithm=MD5,qop="auth"
Content-Length: 0
019130: Jul  4 19:11:13.412: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK304119018
To: Andy <240>
Call-ID: 1572679096
CSeq: 3 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="F1A491ED0505BB83", uri="sip:10.1.10.2", response="532d0207698dc58739e22c46a23820ee", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019131: Jul  4 19:11:13.416: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1572679096
CSeq: 3 REGISTER
Content-Length: 0
019132: Jul  4 19:11:13.420: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1572679096
CSeq: 3 REGISTER
WWW-Authenticate: Digest realm="",nonce="988AB5FF0505BB84",algorithm=MD5,qop="auth"
Content-Length: 0
019133: Jul  4 19:11:13.424: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK263491621
To: Andy <240>
Call-ID: 1572679096
CSeq: 4 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="988AB5FF0505BB84", uri="sip:10.1.10.2", response="ea6345f75223f9e0ef8e123757fc9d51", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019134: Jul  4 19:11:13.428: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1572679096
CSeq: 4 REGISTER
Content-Length: 0
019135: Jul  4 19:11:13.428: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1572679096
CSeq: 4 REGISTER
WWW-Authenticate: Digest realm="",nonce="4647C1E10505BB85",algorithm=MD5,qop="auth"
Content-Length: 0
019136: Jul  4 19:11:14.360: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1687743136
To: Andy <240>
Call-ID: 1948353677
CSeq: 1 REGISTER
Contact: <240>
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019137: Jul  4 19:11:14.364: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: Andy <240>
Date: Wed, 04 Jul 2012 19:11:14 GMT
Call-ID: 1948353677
CSeq: 1 REGISTER
Content-Length: 0
019138: Jul  4 19:11:14.364: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: Andy <240>;tag=323956D8-0
Call-ID: 1948353677
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="",nonce="499CD3060505BBE2",algorithm=MD5,qop="auth"
Content-Length: 0
019139: Jul  4 19:11:14.400: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK197596454
To: Andy <240>
Call-ID: 1948353677
CSeq: 2 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="499CD3060505BBE2", uri="sip:10.1.10.2", response="8b49845683fdd7de7d00097547ba020b", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019140: Jul  4 19:11:14.404: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1948353677
CSeq: 2 REGISTER
Content-Length: 0
019141: Jul  4 19:11:14.404: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1948353677
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="",nonce="DF20CBE70505BBE6",algorithm=MD5,qop="auth"
Content-Length: 0
019142: Jul  4 19:11:14.556: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1846225244
To: Andy <240>
Call-ID: 1948353677
CSeq: 3 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="DF20CBE70505BBE6", uri="sip:10.1.10.2", response="b2436385782cf04a3c00cfab24820105", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019143: Jul  4 19:11:14.560: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDispla
uc540#yMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1948353677
CSeq: 3 REGISTER
Content-Length: 0
019144: Jul  4 19:11:14.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1948353677
CSeq: 3 REGISTER
WWW-Authenticate: Digest realm="",nonce="CC8B0CD00505BBF6",algorithm=MD5,qop="auth"
Content-Length: 0
019145: Jul  4 19:11:14.616: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.10.12:5060;rport;branch=z9hG4bK1058964990
To: Andy <240>
Call-ID: 1948353677
CSeq: 4 REGISTER
Contact: <240>
Authorization: Digest username="240", nonce="CC8B0CD00505BBF6", uri="sip:10.1.10.2", response="f8bc74e398606745ccb12e767894d7da", algorithm=MD5, cnonce="0a4f113b", qop=auth, nc=00000001
Max-Forwards: 70
Expires: 1800
Supported: 100rel
Supported: path
Content-Length: 0
019146: Jul  4 19:11:14.624: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Call-ID: 1948353677
CSeq: 4 REGISTER
Content-Length: 0
019147: Jul  4 19:11:14.624: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID: 1948353677
CSeq: 4 REGISTER
WWW-Authenticate: Digest realm="",nonce="54ADB5950505BBFC",algorithm=MD5,qop="auth"
Content-Length: 0
uc540#
Regards.
Hello Daniele,
Sorry Ive been out of town for a few days. Before I left I removed the authentication all together and it now logs in, registers with SIP server on the UC540. I can try to get the auth to work later. I was able to recieve a call from a cisco sccp phone to the 240 extention number on the SIP phone which is great. When I try outbound calling I get the message unaccebtable media. I'll try changing the codec see if that fixes it.I have an outside line POTs on an FXO port. I have the number of the POTs appearing as a line button on all the other Cisco phones. Can I have the SIP phone also be included in that number? Or can you not mix the SIP and SCCP?
Daniele you got me up and running appreciate your help.
Andy
Andy,
voice class codec 1
 voice-class codec 1
Best,
David
Hello David,
Thanks for your help with the CODEC command. I can now make calls within the UC540 to other SCCP phones. However when I dial a 9 to dial outside the call is routed out the correct trunk. Its an FXO port to the telco. I can see the call being routed via the debugs. The call shows as established on the SIP phone but the call never goes through to the outside phone. Its as though for some reason the digits are not be passed. I can see the trunk going off hook toward the telco.
All of the SCCP phones use the same trunk to dial out from the UC540 I know the trunk is OK. Is there some type of translation that needs to happen going out to the Telco from SIP to PSTN thats not happening?
I have attached the output of a debug below.
Andy
032123: Jul 10 04:28:59.702: VOICE REGISTER POOL-1 has registered. Name:SEP7CC3A1A1EF11  IP:192.168.10.12  DeviceType:Phone
uc540#
032124: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=93038100583, Called Number=93038100583, Peer Info Type=DIALPEER_INFO_SPEECH
032125: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=93038100583
032126: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=93038100583, Expanded String=93038100583, Calling Number=93038100583T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
032127: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=70 Is Matched
032128: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
032129: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=93038100583, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
032130: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=70
032131: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=240, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
032132: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=240
032133: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
032134: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=240T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
032135: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032136: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032137: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=240
032138: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032139: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032140: Jul 10 04:29:18.171: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=40001 Is Matched
032141: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032142: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40001
032143: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugi
uc540#n:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
032144: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
032145: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032146: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032147: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032148: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032149: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032150: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032151: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032152: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032153: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032154: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032155: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032156: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032157: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032158: Jul 10 04:29:18.175: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
032159: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpAssociateIncomingPeerCore:
   Calling Number=240, Called Number=93038100583, Voice-Interface=0x0,
032160: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpAssociateIncomingPeerCore:
032161: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpMatchPeertype:
032162: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpMatchCore:
032163: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/MatchNextPeer:
032164: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpMatchPeertype:exit@5912
032165: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpAssociateIncomingPeerCore:
032166: Jul 10 04:29:18.175: //-1/A5C000818681/DPM/dpMatchSafModulePlugin:
032167: Jul 10 04:29:18.179: //-1/A5C000818681/DPM/dpAssociateIncomingPeerSPI:exit@6475
032168: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=93038100583, Peer Info Type=DIALPEER_INFO_SPEECH
032169: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchPeersCore:
032170: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchCore:
032171: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/MatchNextPeer:
032172: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchPeersCore:
032173: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchSafModulePlugin:
   dialstring=93038100583, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
032174: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=70
032175: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchPeersCore:
   Calling N
uc540#umber=, Called Number=93038100583, Peer Info Type=DIALPEER_INFO_SPEECH
032176: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchPeersCore:
032177: Jul 10 04:29:18.183: //-1/A5C000818681/DPM/dpMatchCore:
032178: Jul 10 04:29:18.187: //-1/A5C000818681/DPM/MatchNextPeer:
032179: Jul 10 04:29:18.187: //-1/A5C000818681/DPM/dpMatchPeersCore:
032180: Jul 10 04:29:18.187: //-1/A5C000818681/DPM/dpMatchSafModulePlugin:
032181: Jul 10 04:29:18.187: //-1/A5C000818681/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=70
032182: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032183: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032184: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032185: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032186: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032187: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032188: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=70
032189: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=93038100583, Called Number=, Voice-Interface=0x0,
032190: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=93038100583
032191: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032192: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=93038100583T
032193: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032194: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032195: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=93038100583
032196: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032197: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032198: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=70 Is Matched
032199: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032200: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
032201: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
032202: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
032203: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032204: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032205: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032206: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032207: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032208: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032209: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032210: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032211: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032212: Jul 10 04:29:18.187: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032213: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032214: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032215: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032216: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
032217: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032218: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032219: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032220: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032221: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032222: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032223: Jul 10 04:29:18.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=70
032224: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/dpMatchPeersCore:
032225: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/dpMatchPeersCore:
032226: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/dpMatchCore:
032227: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/MatchNextPeer:
032228: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/dpMatchPeersCore:
032229: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/dpMatchSafModulePlugin:
032230: Jul 10 04:29:18.191: //-1/A5C000818681/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=70
uc540#
032231: Jul 10 04:29:21.823: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=240, Peer Info Type=DIALPEER_INFO_SPEECH
032232: Jul 10 04:29:21.823: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=240
032233: Jul 10 04:29:21.827: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=240, Expanded String=240, Calling Number=
032234: Jul 10 04:29:21.827: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=40001 Is Matched
032235: Jul 10 04:29:21.827: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032236: Jul 10 04:29:21.827: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032237: Jul 10 04:29:21.827: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=40001
032238: Jul 10 04:29:21.827: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032239: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032240: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032241: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032242: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032243: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032244: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
032245: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=3038100583, Peer Info Type=DIALPEER_INFO_SPEECH
032246: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=3038100583
032247: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=3038100583, Expanded String=3038100583, Calling Number=
032248: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=3 Is Matched
032249: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032250: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032251: Jul 10 04:29:21.831: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
032252: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032253: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032254: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032255: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032256: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032257: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032258: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
032259: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032260: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032261: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032262: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032263: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
032264: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032265: Jul 10 04:29:21.839: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1:
uc540#Dial-peer Tag=3
032266: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032267: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032268: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032269: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032270: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032271: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032272: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032273: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032274: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032275: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032276: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032277: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032278: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032279: Jul 10 04:29:21.843: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
032280: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032281: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032282: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032283: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032284: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032285: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032286: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032287: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032288: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032289: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032290: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032291: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032292: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
uc540#dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
032293: Jul 10 04:29:22.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
032294: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032295: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032296: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032297: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032298: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
032299: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032300: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032301: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
032302: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
032303: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
032304: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5912
032305: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
032306: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
032307: Jul 10 04:29:23.343: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6524
uc540#
Hi Andy,
Would you mind posting the relevant portions of your config?
Best,
David
No Problem David I'll do that.
Appreciate you taking a look.
Andy
Hello Davaid,
Below is the relevant configuration..
andy
uc540#sh run
Building configuration...
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/0/0
  fallback-dn 301
port 0/0/1
  fallback-dn 302
port 0/0/2
  fallback-dn 303
port 0/0/3
  fallback-dn 304
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
  registrar server expires max 600 min 60
  localhost dns:networkwise.net
  no update-callerid
voice class codec 1
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
mode cme
source-address 10.1.10.2 port 5060
max-dn 4
max-pool 4
create profile sync 0428016071226796
voice register dn  1
number 240
name Andy's SIP Phone
label 240
number 1 dn 1
dtmf-relay rtp-nte
voice-class codec 1
username 240 password siptestpw
no vad
voice translation-rule 1
rule 1 /^1303\(.*\)/ /9303\1/
rule 2 /^1720\(.*\)/ /9720\1/
rule 3 /\(...........\)/ /9\1/
voice translation-rule 4
rule 15 // //
voice translation-rule 5
rule 1 /17204964507/ /205/
voice translation-rule 410
voice translation-rule 411
rule 1 /^5\(.*\)/ /ABCD5\1/
rule 2 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 1 /^ABCD91900......./ //
rule 2 /^ABCD91976......./ //
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 555
rule 1 /^555/ /18005927303,,,,,,1244573701/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 15 /^...$/ /99051000122528/
voice translation-rule 1112
rule 1 /^9303/ /1303/
rule 2 /^9720/ /1720/
rule 3 /^9/ //
voice translation-rule 1113
rule 3 /^9/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile 1800-Phone-card
translate called 555
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile FXO_OUT_TRANSLATION_PROFILE
translate called 1113
voice translation-profile Missed_Recieved_Calls
translate calling 1
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
translate called 1112
voice translation-profile SIP-DID_Called_5
translate called 5
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_OUT_TRANSLATION_PROFILE
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
interface Null0
no ip unreachables
interface FastEthernet0/0
description $FW_OUTSIDE$
bandwidth 4000
ip address dhcp client-id FastEthernet0/0
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat outside
ip inspect SDM_MEDIUM out
load-interval 30
duplex auto
speed auto
service-policy input sdmappfwp2p_SDM_MEDIUM
service-policy output shape
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
description Tmobile Connection
interface FastEthernet0/1/2
description John Smith
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
description Desk Phone
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip local pool SDM_POOL_1 192.168.10.128 192.168.10.137
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
route-map SDM_RMAP_1 permit 1
match ip address 105
control-plane
bridge 1 route ip
bridge 100 route ip
call threshold interface FastEthernet0/0 int-calls low 4 high 4
voice-port 0/0/0 *****************************Analog Phones FXS************************
station-id number 301
caller-id enable
voice-port 0/0/1
station-id number 302
caller-id enable
voice-port 0/0/2
shutdown
station-id number 303
caller-id enable
voice-port 0/0/3
shutdown
station-id number 304
caller-id enable
voice-port 0/1/0 *************************************FXO Connection To Telco******************* Outbound call from SIP Phone is seizing this trunk..
trunk-group ALL_FXO
translation-profile incoming Missed_Recieved_Calls
supervisory disconnect dualtone mid-call
timeouts call-disconnect 2
timeouts wait-release 2
connection plar opx 801
description Configured by CCA 4FXO-0/1/0-Custom-CO0
caller-id enable
voice-port 0/1/1************************************Other FXO Connection To Telco************
connection plar opx 802
description Configured by CCA 4 FXO-0/1/1-CO1
caller-id enable
voice-port 0/1/2
connection plar 203
caller-id enable
voice-port 0/1/3
connection plar 204
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtp00270d4b8540
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Skype for SIP
codec g711ulaw
codec g729abr8
codec g729ar8
maximum sessions 10
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name PSTN-fax
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list call-fax
member PSTN-fax
dial-peer voice 1 pots
description ** CCA Analog Fax **
destination-pattern 301
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 302
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 303
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 304
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description ^Scatch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing FXO_OUT_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
description **CCA*North American-10-digit*Toll-Free**
translation-profile outgoing 1800-Phone-card
preference 1
destination-pattern 555
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*10 Digit Local**
preference 5
destination-pattern 9720.......
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 9303.......
forward-digits all
no sip-register
dial-peer voice 3000 voip
description SIP-DID
translation-profile incoming SIP-DID_Called_5
session target sip-server
incoming called-number 17204964507
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^...$
dtmf-relay rtp-nte
codec g711ulaw
no vad
no dial-peer outbound status-check pots
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 2 mtp00270d4b8540
video
authentication credential admin cisco
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
service phone videoCapability 1
service phone ehookenable 1
service phone SPA525-Encryption-key P00d1ing
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
service phone SPA525-SSID cisco-voice
service phone SPA525-readonly no
service phone SPA525-Encryption-type WPA2_PSK
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Cisco Small Business
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.4SR1
load 7925 CP7925G-1.3.4SR1
load 7931 SCCP31.8-5-3S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-3S
load 7941GE SCCP41.8-5-3S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-3S
load 7961 SCCP41.8-5-3S
load 7961GE SCCP41.8-5-3S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-3S
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-4
load 501G spa5x5-7-4-4
load 502G spa5x5-7-4-4
load 504G spa5x5-7-4-4
load 508G spa5x5-7-4-4
load 509G spa5x5-7-4-4
time-zone 5
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
n-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Jan 02 2011 13:59:25
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 201 no-reg primary
label 201
description andy
name andy
call-forward busy 399
call-forward noan 399 timeout 20
huntstop channel
ephone-dn  292
number 704 no-reg primary
park-slot
label Park Slot 704
ephone-dn  293
number 703 no-reg primary
park-slot
label Park Slot 703
ephone-dn  294
number 702 no-reg primary
park-slot
label Park Slot 702
ephone-dn  295
number 701 no-reg primary
park-slot
label Park Slot 701
ephone-dn  296  dual-line
number 801 no-reg primary
label 720-224-7707
description andy
name andy
trunk A0
ephone-dn  297  dual-line
number 802 no-reg primary
label 720-890-8039
description andy
name andy
trunk A1
ephone-dn  298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
description andy
video
mac-address 0016.46CB.4797
ephone-template 16
username "andy" password
  type 7960
button  1:10 2:296 3:297 4:14
ephone  2
description andy cipcphone
video
mac-address 0018.DE76.C514
ephone-template 16
username "andy-cipc-home" password
mtp
type CIPC
button  1:10 2f296 3:297 4:14
ephone  3
video
mac-address 0005.9A3C.7800
ephone-template 16
username "andy-cipc-office" password
mtp
type CIPC
ephone  6
video
mac-address 0007.0EF7.3BEA
type 7960
button  1:12
alias exec cca_voice_mode KEYSYSTEM
uc540#
Hello David,
It appears I may have problems with the FXO connection. Im not getting dialtone from the line that connects to the voice FXO port 0/1/0. This may be the problem. The SCCP phones are not able to dial out via this line either.
I'll take a look.
Thanks David.
Andy
Andy,
That changes things. Let me know what you find re: that fxo port. Did you test the actual phone line with an analog phone?
Best,
David
Hello David,
There was a problem with the FXO line. I can now make outbound calls via the 3rd party SIP phone.
Appreciate your help.
Andy
Andy,
Glad to hear its all worked out
Have a good day.
Best,
David
