Cisco AIR-AP1815W-B-K9 console adapter
Not applicable
We just bought 103 of these 1815w access points.
The AP has a miniature connector for the console port.
The documentation says there is a custom 4-pin connector for the console AIR-CONSADPT=.
I cannot find this connector anywhere on the Cisco site.
Is available to purchase?  Or is there an alternative adapter?
26 Replies 26
Does anyone know what the pinout of this connector is? I can't find that anywhere and it's like 2 weeks to actually get one in hand.
Thanks, but I'm looking for the pinout of the console for the 1815w. It is a 4 pin mini molex connector on the back. i.e. I want to get by without buying the AIR-CONSADPT= and use my own adapter.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/console_adptr/guide/air_console_adptr.pdf
Oh I'm sorry, I didn't realize that they don't use the usual RJ45 plug for this AP model.
The manual (sadly) states this: "You will require the custom four-pin adapter AIR-CONSADPT= to use this port."
Source: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1815/quick/guide/ap1815wgetstart.html#pgfId-56220
Dang it Cisco... killing me. These adapters aren't just laying around either.
Thanks!
Finally got a homegrown solution to the console cable to use with the 1815w
https://www.amazon.com/gp/product/B00QT7LQ88
Use this cable and the following pinout
pin 2 <-> white
pin 3 <-> green
pin 4 <-> black
You'll need a 4 pin molex connector to get on the console of the board, but hey, it works!
Here is the Molex connector
https://www.molex.com/molex/products/datasheet.jsp?part=active/0510210400_CRIMP_HOUSINGS.xml&channel=Products
And here it is from Digikey. Digikey will list all the parts needed to make this as well.
https://www.digikey.com/product-detail/en/molex/0510210400/WM1722-ND/242844
I do not post in here often, but @ctbower98 was spot on with his info with the adapter from amazon.  That worked perfect and saved me 40 days of waiting for a part that was no where to be found in stock anywhere.
Thank You!
Thanks ctbower98 this worked perfectly for me. Amazon had the adapter in stock and I was able to order the little Molex connectors and appropriate sized female inserts right from the Molex site.
Hi Razelle,
can you please send me pics of it. Esp. 4 pin 1.25mm Picoblade female pin layouts (which one is 1,2,3,4) I guess USB A remains 1 Red, 2 white, 3 Green, 4 Black. Also additionally any driver or software needed other than Putty?
Thanks & Regards
Rai
No additional drivers were needed for the adapter on W10 & 11 Windows found the drivers and Yes it works with Putty.
Hi Ctbower98 can you send me pics of it. Esp. 4 pin 1.25mm Picoblade female pin layouts (which one is 1,2,3,4) I guess USB A remains 1 Red, 2 white, 3 Green, 4 Black. Also additionally any driver or software needed other than Putty?
Thanks & Regards
Rai
Hi Ctbower98,
can you please send me pics of it. Esp. 4 pin 1.25mm Picoblade female pin layouts (which one is 1,2,3,4) I guess USB A remains 1 Red, 2 white, 3 Green, 4 Black. Also additionally any driver or software needed other than Putty? as first link is not valid for now.
Thanks & Regards
Rai
