ASR9K POwer Modules
Can an ASR9K work with two modules of different version?
for exemple I Have
NODE power-module 0/PM0/SP 2kW DC Power Module
MAIN: board type 0xf0038a
S/N: DTM173103UE
Top Assy. Number: 341-00400-02
PID: PWR-2KW-DC-V2
HwRev (UDI_VID): V01
Chip HwRev: V0.0
New Deviation Number: 0
CLEI: IPUPAHYAAA
Board State : PRESENT
PLD: Motherboard: N/A, Processor: N/A, Power: N/A
Board FPGA/CPLD/ASIC Hardware Revision:
NODE power-module 0/PM1/SP 2kW DC Power Module
S/N: ART1838Y095
Top Assy. Number: 341-00400-04
PID: PWR-2KW-DC-V2
HwRev (UDI_VID): V03
Chip HwRev: V0.0
CLEI: IPUPAMDAAA
The new one I want to Add have indication below :
PID VID :
CRS-PM-DC V03
5 Replies 5
balaji.bandi
Personally not worked on these model, but i have seen on Cat 6500 Different version PSU works, as long as both are same capacity.
BB
tkarnani
Version 1 and Version 3 power supplies are different sizes. v1 tray will hold 3 power supplies, v2/3 will hold 4
they will not be able to fit in the same tray
https://www.cisco.com/c/en/us/td/docs/iosxr/asr9000/hardware-install/hig/b-asr9k-hardware-installation-guide/b-asr9k-hardware-installation-guide_chapter_011.html
in general it is recommended to have the same version of power supply on the system
Thank you dear for your comment
I m talking  about power module DC 2100W they  have the same tray  and as you can see on the result of the commande
-01#admin show diag power-supply
Thu Sep 23 12:30:37.461 GMT
S/N: DTM173103UE
PID: PWR-2KW-DC-V2
Chip HwRev: V0.0
CLEI: IPUPAHYAAA
S/N: ART1838Y095
PID: PWR-2KW-DC-V2
Chip HwRev: V0.0
--More--
as long as the PID is the same "PID: PWR-2KW-DC-V2"
you should be ok, the hwrev is for internal manufacturing rather than version difference
[cid:a6880b10-edd4-425c-a663-c5baef8d6059]
What about this module it s for CRS or cab be used also for ASR9K?
________________________________
« Ce message et toutes les pièces y jointes sont susceptibles de contenir des informations confidentielles ou privilégiées, lesquelles ne doivent être reproduites, diffusées ou exploitées sans autorisation. L’intégrité des messages électroniques n’étant pas garantie, WANA CORPORATE décline toute responsabilité dans le cas où ce message aurait été altéré, déformé ou falsifié.
Ce message est établi à l'attention exclusive de ses destinataires. Si vous avez reçu ce message par erreur, veuillez le signaler à l’expéditeur et le détruire y compris les pièces jointes.
Merci. »
« This message and its attachments may contain confidential or privileged information that should not be copied, distributed or used without authorization. As the integrity of emails may not be guaranteed, WANA CORPORATE is not liable for messages that have been modified, changed or falsified.
If you have received this email in error, please notify the sender and delete this message and its attachments.
Thank you. »
