XRv 5.1.1 - Working/non working features and roadmap
daniel.dib
Level 7
Level 7
Cisco recently released Cisco XRv 5.1.1 which is IOS XR running in a VM. I thought it would be nice track features working not working and if Cisco could comment on the roadmap.
Working:
ISIS
BGP
LDP
Not working:
EoMPLS
VPLS
Control plane is up for EoMPLS and VPLS but no traffic passes through. Post anything you have tested.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
48 Replies 48
sharawy_2001
Can any one advice , i tried to allocate labels for specfic routes using :
mpls ldp
mpls ldp  label   allocate for 1
1 is ip access list . but it doesn't work .. any one try this , any suggestions , please support ?
LOOL I found solultion :
http://wiki.kemot-net.com/mpls-ldp-local-label-allocation-filtering
dean holroyd
have some issues with multicast forwarding out of interfaces on which an IGMP join was received? inside the PIM network, I don't see this
RP/0/0/CPU0:XR8#RP/0/0/CPU0:Oct 17 12:30:25.552 : netio[310]: MFIB-ingress: Failed to set deliver list in pak - 'PIRD' detected the 'fatal' condition 'Invalid node ID specified for nodeset'
RP/0/0/CPU0:Oct 17 12:30:27.632 : netio[310]: MFIB-ingress: Failed to set deliver list in pak - 'PIRD' detected the 'fatal' condition 'Invalid node ID specified for nodeset'
RP/0/0/CPU0:Oct 17 12:30:29.662 : netio[310]: MFIB-ingress: Failed to set deliver list in pak - 'PIRD' detected the 'fatal' condition 'Invalid node ID specified for nodeset'
RP/0/0/CPU0:XR8#sh mfib ipv4 counter
Fri Oct 17 12:31:05.189 UTC
MFIB global counters are :
* Packets [no input idb]                             : 0
* Packets [failed route lookup]                      : 0
* Packets [Failed idb lookup]                        : 0
* Packets [Mcast disabled on input I/F]              : 0
* Packets [encap drops due to ratelimit]             : 0
* Packets [MC disabled on input I/F (iarm nfn)]      : 0
* Packets [IC ignored due to IDB unlinked from VRF]  : 0
* Packets [MVPN TTL 1 decapped]                      : 0
* Packets [Failed TTL check]                         : 0
* Packets [Outgoing list error]                      : 0
* Packets [Failed FSV get]                           : 0
* Packets [Failed fint idb lookup]                   : 0
* Packets [Failed to send pkt to LC]                 : 252
* Packets [Already delivered by HW]                  : 0
* Packets [Miscellaneous Failure]                    : 5
* Packets [Invalid interface handle]                 : 0
* Packets [Null route]                               : 0
* Packets [Drop preserved packets]                   : 0
* Packets [Send to fabric failed]                    : 0
* Packets [Preserved packet is stale]                : 0
Hi Guys.
Though some reported XRv problems with multicast vpn.
Can somebody really confirm if this is supported with XRv?
appreciate your help guys.
thanks
