XRv 5.1.1 - Working/non working features and roadmap
daniel.dib
Level 7
Level 7
Cisco recently released Cisco XRv 5.1.1 which is IOS XR running in a VM. I thought it would be nice track features working not working and if Cisco could comment on the roadmap.
Working:
ISIS
BGP
LDP
Not working:
EoMPLS
VPLS
Control plane is up for EoMPLS and VPLS but no traffic passes through. Post anything you have tested.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
48 Replies 48
Does ABF without VRF work?
hantopia88
I guess the same for l2vpn xconnect?  I set it up and it doesn't work.
Yes, as mentioned before, l2vpn / vpls is not supported yet.
--Vinit
Hi Vinit,
For L2VPN, is data-plane already supported on higher versions? Let's say 6.x something.
Chris
pavel.stefanov
Multicast routing does not seem to work over MPLS P2MP TE tunnels. Although the packets show up as forwarded out the MTE interface, they are not. I ran a packet capture to confirm this.
RP/0/0/CPU0:XR1#sh mfib  int tunnel-mte5
Sat Mar  1 13:43:45.131 UTC
Interface : tunnel-mte5 (Enabled)
SW Mcast pkts in : 0, SW Mcast pkts out : 100
TTL Threshold : 0
Ref Count : 5
jasper_arevalo
Hi all,
Can you please help me.I have setup my XRv using vbox and gns3 but when i run the XRv my ping not working. My interface at both up.
Hi Jasper,
Did you allow all the vlans on the interface on the vm side.
Also, what kind of interfaces have you added on the vbox. is it E1000.
Vinit
--Vinit
Hi vinijain,
On the vbox under promiscuous mode i set it to allow VMs then on adapter i set it on 1000 m server.
Once in in a while I have disconnect and reconnect the cables in GNS3 to get pings to work.  This really stumped me be the first - I watched a 10 minute video which repeated all the step I already did, and then at the end there was a quick blurb about this bug.
jasper_arevalo
Daniel.dib can you please share your setting on XRv vm.
pavel.stefanov
TE path protection also not supported on XRv.
RP/0/0/CPU0:XR1(config-if)#show conf failed
Thu Mar  6 22:45:07.297 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface tunnel-te0
path-protection
!!% The requested operation is not supported: Path-protection is not supported on this platform
end
tomlig001
Can't enter following commands:
1) (config)#mpls ldp router-id loopback 0
% Invalid input detected at '^' marker.
2) Command completion doesn't work for
mpls ldp
label
   local
    advertise
     explicit-null
hierarcy.
3) Despite the fact I have loopback properly configured, I don't see LDP binding for it on remore router.
4) Locally I see
10.19.19.16/32, rev 2
        Local binding: label: ImpNull
        No remote bindings
despite explicit-null configured in 2)
Any advice ?
Hi ,
i guess this link will help explaining how to allocate implicit null.
http://wiki.kemot-net.com/mpls-ldp-local-label-allocation-filtering.
Good Luck :)
Brent Crier
As far as I can tell bundle-ether interfaces do not work at least with my basic set. Can someone else confirm?
RP/0/0/CPU0:GCT#show run int bundle-ether 1
Wed Apr 23 20:06:37.109 UTC
interface Bundle-Ether1
 ipv4 address 192.168.99.1 255.255.255.0
RP/0/0/CPU0:GCT(config)#show
Wed Apr 23 20:07:02.347 UTC
Building configuration...
!! IOS XR Configuration 5.1.1
interface GigabitEthernet0/0/0/5
 bundle id 1 mode on
end
RP/0/0/CPU0:GCT(config)#commi
Wed Apr 23 20:07:10.927 UTC
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/0/CPU0:GCT(config)#show configuration failed
Wed Apr 23 20:08:36.461 UTC
!! found below.
 bundle id 1 mode on
!!% 'CfgMgr' detected the 'fatal' condition 'This configuration has not been verified and can not be accepted by the system.'
end
dangleminh
ISIS seems does not work with sub-interface on XRV :D
