02-17-2016 06:38 AM - edited 03-14-2019 03:46 PM
Can someone please share how the post call survey works in UCCX Rls 11. Specially how and where to save the post call survey data.
Thank you
Solved! Go to Solution.
02-17-2016 06:49 AM
It's up to you. The post call survey feature is just an automated post-call transfer to another application.
What that app does is down to your programming - you might use custom vars to store in the CCX DB, or you might store in an external database server or other system.
Aaron
02-17-2016 07:11 AM
Refer to below document in order to configure Post Call in UCCX 11:
http://www.cisco.com/c/en/us/support/docs/customer-collaboration/unified-contact-center-express/119428-technote-uccx-00.html
In case you are looking for a Sample Survey script, then refer to below thread:
https://supportforums.cisco.com/discussion/12760656/post-call-survey-106
Deepak
02-17-2016 06:49 AM
Aaron
02-17-2016 07:44 AM
Thank you
10-29-2018 03:19 PM
To store in the CCX DB or store in an external database server, is needed the Premium License?
TIA
Cristian
02-17-2016 07:11 AM
Deepak
02-17-2016 07:43 AM
Thank you Deepak
02-17-2016 07:45 AM
My Pleasure Alex :) and thanks for updating the forum.
Deepak
08-31-2018 12:53 PM
10-29-2018 03:16 PM
I have the same doubt.
08-21-2019 04:26 PM
How can you associate the original agent to the survey in a UCCX report? I'm trying to get a custom call peripheral variable set to the agent ID but I have to do this after the resource is selected. If I do this, it works on the report but all other call peripheral variables get unset by this, such as calling party ID. Any other ideas?
