9951 is a phone with Touchscreen or not?
Gary Tong
In 9951 datasheet, it said that "Newly developed ergonomic design and user experience designed for use with the VGA touchscreen display". But in the other materials, it is not touchscreen.
14 Replies 14
Paul Reck
Hi there,
I believe only the 9971 is touchscreen, but maybe someone who has had some 'hands on' can confirm,
regards,
Paul
Thank you, Paul.
I also suspect there is some mistake in the datasheet of 9951. Hope Cisco can clarify or revise it soon.
9971 is touch screen but 9951 isn't.
Thank you, Anil. Do you have any document may help me to verify it? Thanks in advance.
Unfotunately don't have any document but came to know from someone.
OK. No problem. Thanks.
If you are a Cisco partner you should be able to access the IP phone ordering guide at the link below.
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/ordering_guide_713_ip_phones_final_oct27.pdf
This states that the 9971 is touchscreen and that the 9951 is not.
Thank you, Jamesha.
Cisco revised 9951 datasheet 2 days ago. All the materials coincide now.
Hi all,
what about 8961 is a phone with Touchscreen or not?
Tahnks,
MM
No, it does not have a touch screen.
Manish
so what is the series support touch screen?
DX650 has a nice touch screen
I think the writing is on the wall for the DX650....
GTG
Please rate all helpful posts.
You can check the 8800 series phones
http://www.cisco.com/c/en/us/products/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-listing.html
Manish
