CUBE to Service Provider SIP Trunk
prash723
We have below call flow
CUCM>>(SIP)>>CUBE ISR3441 >> (SIP) >> Service Provider.
Service provider tested the connection, Please check in the screenshot.
CUBE IP : 192.168.3.50
Service Provider IP: 192.168.3.1
please suggest the configuration.
Hi Roger,
I have configured rest invoirnment except SIP between service provider and gatewat. I am receiving the calls on but it is getting disconnected after 20 sec and only one direction sound.
This is my gateway configuration.
Sorry, but with the information given there is no way that anyone can help you out with this. Advice you to seek help from a experienced and reputable systems integrator with a specialization in Cisco Unified Communication.
Response Signature
Hi Roger,
Check with the ITSP the configurations that them support. (dial-plan, type of media offer, sip-header configurations and so on..)
There are many docs at Cisco and on the internet about this:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117300-configure-cube-00.html
https://www.cisco.com/c/pt_br/support/unified-communications/unified-border-element/products-installation-and-configuration-guides-list.html
https://ucpros.net/cube-configuration-part-1/
Leonardo Santana
*** Rate All Helpful Responses***
Scott Leport
Level 7
Level 7
Based on the bit of info you’ve supplied, it looks like you need to configure your CUBE to register with your ITSP.
You (or your Cisco partner) will need to work with your ITSP to determine the exact configuration requirements to get the trunk operational. Generally you need registration and authentication configuration for successful inbound and outbound calls.
The multi-tenant section of this link here will assist, in addition to the links Leonardo provided below:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/ios-xe/config/ios-xe-book/m_voi-cube-multi-tenants.html
Good luck!
