02-16-2018 04:52 AM - edited 03-17-2019 12:13 PM
Hi All,
I have recently installed a new CUCM 11.5 SU4 cluster and the publisher server is reporting high Active Partiton usage. I cant see what would be causing this. Its not impacting operations. Is this anything to be concerned about?
Total Free Used
Disk/active 14154228K 403088K 13606012K (98%)
Disk/inactive 14154228K 11545168K 1883404K (15%)
Disk/logging 49573612K 27944196K 19104488K (41%)
03-20-2018 03:44 AM - edited 03-20-2018 03:44 AM
Did you do anything to resolve this, I have the same on two new installs both 11.5.1 SU4?
03-20-2018 03:48 AM
Raise a TAC case for it.
also is there anything in the release notes that could indicate a cause?
02-13-2019 08:58 PM
Seeing this as well. Fresh installed base 11.5 today on a brand new BE7K, then manually upgraded to 11.5 SU5. All in one day, no configuration at all done yet.
Noted the disk usage when we installed 11.5 base at 91%, proceeded to upgrade and it went up to 92% and has stayed there.
Anyone find any resolution other than "it should be fine"?
02-13-2019 09:58 PM
Try Reinstalling the CUCM using OVA templates other than 1000 User One.
** Do rate helpful post, press the star button below.
03-20-2018 06:36 PM
Refer to these similar posts.
http://docwiki.cisco.com/wiki/Troubleshooting_DiskSpace_and_Partition_related_alerts
HTH.
03-26-2018 12:02 PM
Did anyone ever find a solution for this? I have a fresh install of 11.5 SU4 with the same issue.
03-26-2018 04:27 PM
I installed version 11.5SU4 of CUCM for couple of customers and I never encountered this kind of problem.
03-27-2018 03:01 AM
03-27-2018 03:13 AM
The response I got from TAC is too generic , as the two systems we have had this issue with, one had very minor config added and the other no config at all just fresh install, so I do find this hard to accept.
04-17-2018 03:46 AM
Hi All,
I received a similar response from TAC that this was normal and expected behaviour. My CUCM has been in operation for over 2 months now and the active partition usage has not changed and there have been no operational issues.
04-17-2018 04:39 PM
