10-23-2013 04:34 PM - edited 03-16-2019 08:02 PM
Hi All,
We have 1 pub and 3 sub. We added a new subscriber to our CUCM cluster but we didnt had the node licenses. Then we got a temp license from Cisco
We added those licenses to our CUCM pub but still we see the node license is not activated
Units authorized: 5
Units used : 4
Units remaining: 1
I am not sure if we have to restart just CM services to activate it or restart Pub and subs??
Any help is much appreciated
Thanks in advance
10-23-2013 05:07 PM
Correct, you will see it used once you start the CM service.
Chris
10-23-2013 05:09 PM
Thanks Chris.
So, we will have to restart only Pub CM service??
10-23-2013 05:11 PM
No need to restart anything, simply activate the service.
10-23-2013 06:24 PM
I did restart CM service on Pub but I still see units used 4.
Units authorized: 5
Units used : 4
Units remaining: 1
Not sure why it is not taking the node license
10-23-2013 07:14 PM
Is CM service activated on all 5 servers?
10-23-2013 07:36 PM
CM service is activated on all 4 servers, but not on the newly added subscriber.
When we try to activate the CM service on new sub, we are getting this error
pdate Failed for the Service(s): Cisco CallManager Service cannot be Activated or Deactivated due to Database Update Failure.
10-23-2013 07:38 PM
Check your database replication, this has nothing to do with licensing.
10-23-2013 10:39 PM
can u share old lic file and new lic file provided by Cisco?
also , share the output of utils dbreplication runtimestate from Publisher.
regds,
aman
10-24-2013 12:55 PM
Hi All,
I opened a TAC case to work on this issue and came to know that it is a known issue, TAC gave me a python script to upload on all servers. I ran that script through root access and the issue got fixed.
Once we activated the services on CUCM sub, it consumed one node license.
Thanks for all your help!!!
10-24-2013 07:02 PM
thanks for update.
Did u ever change the security password on Publisher before installing the new Subscriber?
regds,
aman
10-25-2013 09:06 AM
Hi Aman,
I forgot to mention in my last update, yes we changed the security password on all servers.So to sync all db passwords, we had to run that script.
Uday
10-24-2013 07:40 PM
This issue is for a caveat when you change the Security Password and passwords are not sincronized locally.
10-25-2013 09:13 PM
Your problem was due to these bugs
DB service is down, after changing the security password.
CLI "set password user security" did not set the correct apps password
regds,
aman
