CUCM upgrade from 11.5 to 15.X
waqas sardar
Hi Team,
Please advise on how to upgrade CUCM from version 11.5 (11.5.1.13900-52) to version 15.X.
Is there a direct upgrade path available? If not, what are the steps for the upgrade?
Thank you.
16 Replies 16
You can find the needed information for this if you read the recommended list of documents for any upgrade. That would be these.
I recommend following the CSR compatibility guide and checking for the recommended versions. Additionally, make sure to read the following resources.
  1. Installation and upgrade guides
  2. Release notes
  3. Read-me guides
  4. Compatibility matrix
  5. Compatibility matrix for VMware
  6. Compatibility matrix for CIMC (applicable for UCS, if using other HW this is N/A)
These resources will provide comprehensive information to answer your question.
Response Signature
The documents that @Roger Kallberg mentioned are crucial to read before the upgrade. Relying solely on someone else’s advice for an upgrade isn’t enough. In your case, you’re planning a Refresh Upgrade. However, please note that Refresh Upgrades from Pre-12.5.x sources to Release 15 are not supported.
In your situation, I recommend migrating from version 11.5 to 15. You have two options:
  1. Prime Collaboration Deployment (PCD): Use this tool for a seamless migration.
  2. Fresh Install with Data Export: Export data from your existing system and perform a fresh installation of version 15.
Response Signature
Has anyone else ran into the import issue with UCM 15, it boots up and when selecting the import option it gets stuck here.
It works for CUCM 12 and 14 but on 15 no go?Screenshot 2024-05-26 145454.png
Best Regards
Do you know if it better now with v15 SU1?
Did you find solution for this issue ?
I recently performed a migration from version 11.5 to 15 using the fresh install option and didn't encounter any errors. Could you outline the steps you performed?
Response Signature
I bypass the media check when I install CUCM 15 because it's a lab environment to check before generating it on production. After import, it gets stuck in a CLI like image where I respond on
could you maybe share a screenshot?
Best Regards
If you see the exact same screen, it seems that the CUCM installation is stuck, not the import of the old cluster data. When you select 'import,' the CUCM installation will proceed, and at some point, it will ask you to configure the network settings. After that, the import of the old cluster data will start.
It looks like you are stuck in the installation of CUCM. Could you try creating a CUCM VM using the latest OVF for CUCM 15 and attempt the installation again?
Additionally, make sure you do the media check. It won't take much time.
Response Signature
The screenshots I shared below are from a fresh install with data export I did two days ago. Your source must be a CD. If you encounter an error at this step, check if the CD got disconnected. Try using the second CD, as there is a bug with CUC OVA CSCwi62194. The workaround is to use the second CD because the first one might get stuck with the message: "Please insert CDROM containing '/ks/cfg'."
If this issue persists, it’s best to reach out to TAC for further assistance.
The actual Data Import happnes  only after you configure the network whch is later.
I encountered another issue during the installation after the data export for 3 out of 5 nodes, which was from CUCM 11.5 to 15. The solution was to export the data again from the source and redo the installation. I thought of sharing this here, assuming it might help someone. Basically, the cause of the failed installation was that the exported tar files were missing a file called pam.d.
Response Signature
I have cucm version 11.5 and I need to upgrade to version 15, I installed ciscocm-migration-service-11-5-1 cop file on the publisher but I can't export the data using "utility system upgrade data export initate " it gives me"excuted command unsuccessfully"
As your question isn't really on topic of the OP it would be recommended for you to create your own post to ask your question.
Response Signature
Have not tested again in the lab, please provide steps taken as per Nithin Eluvathingal request.
From there one can investigate further.
Best Regards
Matrix_Neo_33
@Nithin Eluvathingal
For option 2, have you conducted a "Fresh Install with Data Export"?
If not wanting to use PCD, wondering what the full steps are for this method as Cisco documentation is lite...
I.e. When deploying the new vm (old Pub shutdown), is there concern for replication to the old nodes (Subscribers) when the new Pub comes up, or is this all addressed after all nodes are completed with the "fresh install and do a full cluster reboot as mentioned when conducting DRS restore of a cluster?
**Intention being to migrate to 15Su1 from 12.5 (address vm requirement with new OVA) while there being limited to no disruption to the phones/service while conducting upgrade with FIWDE method.
