I can´t logging to Prime License Manager
gsilva
Hi all,
We have CUCM 10.5 with Prime License manager coresident, but I can´t logging to Prime License Manager.
When I put the user and password and press button start session, the system try to enter,  but never finish.
Please your help
regards,
Guillermo
8 Replies 8
Aman Soi
Was this working earlier ?
could be issue due to this recent bug
Prime License Manager blank login page/unable to login
CSCur95552
Symptom:
Blank login screen or login failures when attempting to use Prime License Manager for both co-resident and Standalone deployments.
Conditions:
Attempting to login to Prime License Manager GUI
Workaround:
Please contact Cisco TAC for workaround.
regds,
aman
Is it you upgraded the CUCM ?
Please refer the below link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/10_5_2/CUCM_BK_CA8D6D40_00_cucm-cli-reference-guide-1052.pdf
Run the command to check the user, license management list users
my case : I recently upgraded the CUCM from 6 to 10 and i was unable to login in to PLM, stating invalid username or password.
When i check with command to just make sure the actual username it was "CCMAdministrator", however i was able to login in to cucm page via username "ccmadministrator"
I see your case might mot be same,however information provided by you is not very much too.
Raaj
Hi Raaj,
I have the same issue ,Can you help me with the solutions
 Nishad KI
Hi Nishad,
Did you performed any migration of the CUCM and then you facing the issue.
If its like that then you make sure your NTP is in compliance and you have to change the password for the PLM via CLI from OS access.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/10_0_1/userguide/CPLM_BK_U7066CD8_00_user-guide-rel-10-0-1/CPLM_BK_U7066CD8_00_user-guide-rel-10-0-1_appendix_0111.html
Please provide more details and exact behavior you are facing ?
Raaj
Thanks Raaj ...
I reset the password of the PLM from the OS admin
Now i am able to login to the PLM ,
Now if the CCM admin password if i reset,The new password will reflect to PLM user also ?
This may sound ridiculous but what browser are you using. I know its very browser strict because i tried using Safari once i experienced similar problem.
This is exactly what resolved my issue. I was using Firefox and kept getting the Invalid username error. But when I tried the IE and Chrome, it worked like it never was an issue. Thanks for your help
phamvinhdat
Level 3
Level 3
I ran into this similar problem but with standalone Prime License Manager. After entered id and password, it just kept clocking for all day long. Restarting service below resolved my login problem.
"utils service restart Cisco Prime LM Admin"
DP
