identify fxo ports
bluesea2010
Level 5
Level 5
Is there a way to identify  analog number  which is connected to fxo from the voice router
Dennis Mink
you should have a dial-peer with a destination pattern pointing to a physical fxs port on your voice gateway.
send config if you want and we can point it out.
(or is this an MGCP controlled FXS card?)
Please remember to rate useful posts, by clicking on the stars below.
here is the conf
voice-port 1/0/0
timing hookflash-out 50
connection plar opx 8200
bearer-cap Speech
voice-port 1/0/1
connection plar opx 8333
voice-port 1/0/2
voice-port 1/0/3
connection plar opx 8201
voice-port 1/0:15
bearer-cap Speech
no mgcp package-capability res-package
no mgcp package-capability fxr-package
dial-peer voice 1001 pots
destination-pattern 001T
port 1/0/1
prefix 00
dial-peer voice 1002 pots
destination-pattern 002T
port 1/0/2
prefix 00
dial-peer voice 1003 pots
destination-pattern 003T
port 1/0/3
prefix 00
Slot numbering goes like - Slot/Subslot/Port. This card is in 1/0 >> 1 is the slot, 0 is the subslot. Check with "show inventory" to see what card in those specific slots/subslots.
From the config, this looks to be a FXO card.
