Inbound calls failing
harresh123
We all of a sudden started seeing inbound calls from carrier failing with Requested channel not available. On testing further we see that the carrier is trying to fork calls on a channel that is already pre-occupied and hence the cisco returns "Requested circuit/channel not available" to the carrier. There is clearly a miss-match in bearer channel status on the gateway vs the carrier. I am not sure what could cause this all of a sudden. We unchecked "inhibhit restart at PRI initialiazation" but to no avail. The only thing that seems to clear up this issue for sometime is a controller reset or a mgcp restart. Any ideas on what else could be causing this?
5 Replies 5
Ratheesh Kumar
Hi there
Seen some cases where "Inhibit restarts at PRI initialization" didn't work in first place.
  • Unchecked this option and Save
  • Reset the GW
  • Reload the GW
 Still Not working,
  • Delete the MGCP GW from CUCM
  • Remove the mgcp/ccm configs
  • Reload the GW
  • Add the GW back into CUCM and make sure to uncheck "Inhibit restarts at PRI initialization" option before adding
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Dennis Mink
Is this a fractional E1? (ISDN 10, 20)?
Please remember to rate useful posts, by clicking on the stars below.
HARIS_HUSSAIN
Try below
In Interface Serial: of PRI change the Isb bchan number.
isdn bchan-number-order {ascending | descending}.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
mariodavila1
We are expexriencing similar issues. Were you able to find a solution or did any of the replies help you fix the issues?
Seems like it "times out" and returns to normal service after a while. I suspect we are having an issue with the carrier.
Not sure why unchecking the "Inhibit restarts at PRI initialization" will resolve this.....
I guess it's worth a try but I don't like guessing...
We had the carrier turn off the B-channel service messaging on their side.
