RTMT Alert SeverityMatch : Critical pam_succeed_if(sshd:auth): error retrieving information about user mlm AppID : Cisco Syslog Agent ClusterID :
Ronit Malhotra
MatchedEvent : Jan  2 07:22:47 CUC02 authpriv 2 sshd[29949]: pam_succeed_if(sshd:auth): error retrieving information about user mlm AppID : Cisco Syslog Agent ClusterID :
NodeID : CUC02
TimeStamp : Thu Jan 02 07:22:48 CST 2014.
I am recieving following alerts, anyway to stop it, or any impact
6 Replies 6
The error is received if you log into DRS site, OS admin site or console via SSH using a wrong password.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas Ăștiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
HI; I am find information whit respect to this error, canÂŽt you helpme to referent this mensage
SyslogSeverityMatchFound events generated:
SeverityMatch : Alert
MatchedEvent : Jul 29 15:21:50 cucm-pub-tri-qro-bansefi-0001 authpriv 1
sshd[1651]: pam_unix(sshd:auth): check pass; user unknown AppID : Cisco
NodeID : cucm-pub-tri-qro-bansefi-0001
thanks
Greetings,
If the error is received when logging into DRS site - OS admin site or console via SSH using a wrong password, wouldn't you also receive the Authentication Failed syslog?  Unless these are reporting two separate log in errors from different sources.  I'm a bit confused.
Number of AuthenticationFailed events exceeds configured threshold during configured interval of time 1 within 3 minutes
 on cluster StandAloneCluster.
There are 2 AuthenticationFailed events (up to 30) received during the monitoring interval
Any insight is greatly appreciated!
Thanks in advance,
D
Nadeem Ahmed
this alert is for security. pam_succeed_if is designed for suceed or failed authentication and this  alert is a warning that a user tried to login to SSH with invalid credential.
Do you get this alert everyday or two? how frequent you are getting this ?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
David Perez
You might want to check with others in I.T. to see if there are any programs on the network that attempt to sign into your systems for security purposes.
I get this alert every other day. It is done by our network / security team’s software. The software attempts to login to the systems using common passwords.
Is there any way to track the ip address that these attempts were made from or only the user ID that was attempted?
