uccx 7
when i am installing uccx 7 in windows 2003 the following error is showing
computer hardware provided by cisco systems ,inc is required to install cisco unified contact center express installation will now abort
10 Replies 10
Aman Soi
Hi Syed,
It seems you are not installing UCCX 7 on Cisco provided MCS Hardware.
Can u share the HW details ?
regds,
aman
Correct, you need to follow the server compatibility list which you can get from release notes or if this is for lab purposes you can install it in vmware.
HTH,
Chris
i m installing vmware
Hi Syed,
can u share the exact error message which comes while doing installation?
regds,
aman
Hi, VMware what? ESXi should work.
G.
we are installing esxi server
Then it must work. I have a UCCX 7.0 running on ESXi and it's doing fine.
Please double check
- are you installing UCCX on the Cisco-provided operating system (a modified Windows 2003 thingie),
- did you allocate at least 80 GB of HDD space.
G.
Erick Bergquist
Level 6
Level 6
Here is a blog post write up on how to do this,
http://www.ccietalk.com/2009/11/03/installing-uccx-7-on-vmware-esxi
Hi Syed,
Please refer the link provided by Mr. Ebergquist.This will help u do the UCCX 7 installation on VM.
regds,
aman
